I'm looking for some suggestions as to how to change the color of layer that will be used within a drawing files for special purposes.
Ideally the code will make the color Red, but change to Black prior to printing.
The "logic" behind the code currently is to differentiate a layer called "Burn" to a highly visible color for the purpose of review by others then, prior to printing, change the color to Black. The firm I'm currently working for uses gray-scale B sided printers only. The firm currently uses Blue for dimension and extension lines so to produce drawings that portray both type of objects "lightly".
Any tips, suggestions, errata or other methodology to accomplish this task is appreciated!
