Looking for a FileSaveAs object primer.
I am using Inventor Apprentice 2011 and VB.Net 2010.
I am trying to use the FileSaveAs object in a loop that will save copies of a number of files
--- Pseudo Code ---
Create oFileSaveAs Object.
For n = 0 to 100
  oFileSaveAs.AddFileToSave(oDoc(n), NewPath \ NewName(n))
Next
oFileSaveAs.ExecuteSaveCopyAs()
--- End Pseudo Code ---
Only one document is copied.
I was under the impression that more that one document could be added and all documents added would be copied.
Is there better documentation on this process?
leefsma
Hi Gruff,
Multiple files can be saved through Apprentice. Below is a VB.Net example that illustrates how to save a copy of an assembly and its dependencies under a new location. This code also handles replacement of references automatically.
Private Sub Save(ByVal FullFilename As String, ByVal newFolder As String, ByVal prefix As String, ByVal suffix As String)
        Dim doc As Inventor.ApprenticeServerDocument = mApprenticeApp.Open(FullFilename)
        SaveRec(newFolder, doc, prefix, suffix)
        mApprenticeApp.FileSaveAs.ExecuteSaveCopyAs()
        doc.Close()
    End Sub
    Private Function newFileName(ByVal prefix As String, ByVal fullFileName As String, ByVal suffix As String) As String
        Dim fileInfo As New IO.FileInfo(fullFileName)
        Return prefix + fileInfo.Name.Substring(0, fileInfo.Name.Length - 4) + suffix + fileInfo.Extension
    End Function
    Private Sub SaveRec(ByRef NewFolder As String, ByRef doc As Inventor.ApprenticeServerDocument, ByVal prefix As String, ByVal suffix As String)
        Dim newFullFilename As String = NewFolder + newFileName(prefix, doc.FullFileName, suffix)
        Try
            mApprenticeApp.FileSaveAs.AddFileToSave(doc, newFullFilename)
            For Each refDoc As Inventor.ApprenticeServerDocument In doc.ReferencedDocuments
                SaveRec(NewFolder, refDoc, prefix, suffix)
            Next
        Catch ex As Exception
            'Content Center Parts will fail
            'System.Windows.Forms.MessageBox.Show(ex.Message, "Exception")
        End Try
    End Sub
Philippe Leefsma
Developer Consultant
Developer Technical Services
Global Subscription & Support
Autodesk EMEA
www.autodesk.com/joinadn
Thank you for the response leefsma,
Perhaps that is what I've been doing wrong.  I've been creating an instance of the FileSaveAs class and using that.
On another note.  I am having trouble repointing the file references after copying the files.
I've not had success using the ReferencedFileDescriptor object
For Each oDesc As Inventor.ReferencedFileDescriptor In oDwg.ReferencedFileDescriptors
  oDesc.PutLogicalFileNameUsingFull(NewFullName)
Next
Is there some method that I need to use to cause the changes to take affect?
