Loft Mapping Transition Points
Genicee
Genicee
I for the life of me cannot figure out how to add MapPointCurve to a Loft feature. There is not much about it in the API Help file.  If anyone has an example how add and set the MapPoints for a loft. I would be very grateful.
JelteDeJong
I did write a blog post on creating a loft feature. Maybe it is some help to you. You can find it here
Jelte de Jong
Blog: hjalte.nl - github.com
Genicee
Thank you for posting that. It helped me get my head around the process. Much thanks!
Hallo everyone, I have another question concerning this matter as well. I have created a loft between 5 sketches and recieved a quite odd result. so I am trying to fix the loft bit moving the map points. But as you see in the picture I have like more than 100 point set. I keep trying to find the one I want to change but I have to try the whole time to get the point set I need highlighted to be able to change it.
Is there any method to easily locate the wanted point set? maybe right clicking it or somethin?
Genicee
Are you not seeing the 'Red Line' that comes from the selected point?
