Load/Unload AddIn Unspecified error Exception from HRESULT: 0x80004005 (E_FAIL)
Hi im having a problem when i unload and unload the PLM addIns,
in the first load/open of inventor adding tabs is all good, but when i unload and load the addin i received the HRESULT: 0x80004005 (E_FAIL) after yellow highlight.
Thanks in advance
CattabianiI
Let's find what is causing error:
- Accessing RibbonTabs is OK?
var i = partRibbon.RibbonTabs.Count
- Move the two methods outside the RibbonTabs.Add method. Are they raising an exception?
- Try to use dummy values for the first three string parameters; in particular the second one must be unique with respect to all other ribbon tabs.
From the manual:
Input string that defines the unique \internal name of the ribbon tab. This is the internal name and is not displayed to the user. The name must be unique with respect to all other ribbon tabs. The name should remain constant in all locales so it can be used to find a specific tab.
Maxim-CADman77
I'd like to know if this issue was solved (and how)?
Please vote for Inventor-Idea Text Search within Option Names
