List Open Drawings using iLogic
andrew_canfield
Message 1 of 10
andrew_canfield
How can all the current open drawings be listed using iLogic?
The list will be used to save & save as pdf all open drawings (already have a rule to save as pdf).
Regards
Andrew
Replies (9)
Message 2 of 10
Curtis_W
Hi @andrew_canfield
You can look at the "ThisApplication.Documents" collection to see all open documents, and then filter by document type, as shown in this example, which adds them to a list
I hope this helps.
Curtis
Dim oDoc As Document
For Each oDoc In ThisApplication.Documents
	If oDoc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
		'print code there
		MessageBox.Show("Printing:  " & vbLf & oDoc.FullFileName, "iLogic")
Next
Message 3 of 10
andrew_canfield
Hello Curtis & thanks for the reply - the code works but my explanation has hit a problem.
I already have code to create a pdf on the desktop & thought (wrongly) 'run rule' instead of "Printing" would print the file described by the text:batch pdf.JPG
if there are 3 drawings open only one is printed - the active document (i think).
Guessing I need to transfer the file path information from your code into the print pdf code - something like:
Here is all the code - will try to merge them
		'print code there
Next
'pass info from above into rule below
'the rule below will print a pdf to a desktop folder with defer updates on
Dim oDoc As Document'
oDoc = ThisApplication.ActiveDocument'
'oValue = oDoc.DrawingSettings.DeferUpdates ()'
oDoc.DrawingSettings.DeferUpdates = "True"'
ThisDoc.Save
Dim oFolder As String = System.Environment.GetFolderPath(System.Environment.SpecialFolder.Desktop) & "\PDF"
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("project", "revision number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If oPDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2'oOptions.Value("Custom_End_Sheet") = 4
 'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFileName & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'------end of iLogic-------
Regards
Andrew
Message 4 of 10
Curtis_W
 Hi @andrew_canfield ,
Maybe something like this.
I hope this helps.
Curtis
Sub main
	'count open drawings
	i = 0
			i+=1
	Next
	'Get user input
	RUsure = MessageBox.Show ( _
	i & " drawings about to print to PDF." _
	& vbLf & "This could take a while, do you want to continue?", "iLogic", _
	MessageBoxButtons.YesNo, MessageBoxIcon.Question)
	If RUsure = vbNo Then
	Return
	Else
			Call PrintPDF(oDoc)
	Next
	If oDoc is ThisApplication.ActiveDocument Then
	oDoc.Save
	MessageBox.Show("PDFs complete", "iLogic")
	Try
		Process.Start(System.Environment.GetFolderPath(System.Environment.SpecialFolder.Desktop) & "\PDF")
	Catch
	End Try
End Sub
Sub PrintPDF(oDoc As Document)
oFileName = Left(oDoc.DisplayName,Len(oDoc.DisplayName)-4)
If oPDFAddIn.HasSaveCopyAsOptions(oDoc, oContext, oOptions) Then
'Publish document
oPDFAddIn.SaveCopyAs(oDoc, oContext, oOptions, oDataMedium)
End Sub
Message 5 of 10
claudio.ibarra
What would you add to make the resulting PDF filenames contain the drawing revisions at the end, before the ".pdf"?
Message 6 of 10
Curtis_W
Hi @claudio.ibarra ,
This should do it.
I hope this helps.
Curtis
Sub main
	i = 0
			i+=1
	Next
	'Get user input
	Return
	Else
			Call PrintPDF(oDoc)
	Next
	oDoc.Save
	Try
	Catch
	End Try
End Sub
oFileName = Left(oDoc.DisplayName, Len(oDoc.DisplayName) -4)
oRevNum = oDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number").value
oDataMedium.FileName = oFolder & "\" & oFileName & "-Rev" &  oRevNum & ".pdf"
'Publish document
End Sub
Message 7 of 10
andrew_canfield
Many Thanks
Message 8 of 10
andrew_canfield
Added a slight tweak (around line 51) - some users have file extensions visible & other don't so....
FileName1 = Left(oDoc.DisplayName, Len(oDoc.DisplayName))
FileName3 = Right (FileName1, 4)
FileName2 = Left(oDoc.DisplayName, Len(oDoc.DisplayName) - 4)
FileName4 = Right (FileName2, 4)
If FileName3 <> ".idw" Then oFileName = FileName1
If FileName4 <> ".idw" Then oFileName = FileName2
'oFileName = Left(oDoc.DisplayName, Len(oDoc.DisplayName))
it may be crude but the returned pdf's don't include ".idw"  (still needs some testing)
Message 9 of 10
andrew_canfield
amendment- thankfully the drawing numbers have a fixed length...
StrLength = FileName1.Length()
If StrLength = 21 Then  oFileName = Left(oDoc.DisplayName, Len(oDoc.DisplayName) - 4)
If StrLength = 17 Then  oFileName = Left(oDoc.DisplayName, Len(oDoc.DisplayName) )
Message 10 of 10
creggo
Any way to take the revision number from model document instead of drawing document?
Running as external rule so might not be possible? 🤔
