List of command included in CommandManager (ilogic)
Hi All,
Can anyone tell me where can I find the list of commands included in CommandManager (ilogic), please?.
Thanks in advance!.
Sergio.D.Suárez
Hi, maybe the following information could be useful. regards
https://spiderinnet2.typepad.com/blog/2012/07/inventor-net-find-all-the-control-definitions-1.html
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Matthew_Policelli
Have these been updated since 2012?
Edit: I suppose I can just run the code at the top of the link you provided and find out.
Frederick_Law
iLogic:
Sub Main()
    Dim oControlDefs As ControlDefinitions
    oControlDefs = ThisApplication.CommandManager.ControlDefinitions
    Dim oControlDef As ControlDefinition
    Dim oList As New ArrayList
    oList.Add( "Command Name " & "Description" )
    For Each oControlDef In oControlDefs
        oList.Add( oControlDef.InternalName & " +++ " & oControlDef.DescriptionText )
    Next
    oWrite = System.IO.File.CreateText("C:\Temp\TEST.txt")
	'Write Array out to String
	For Each Item As String In oList
		oWrite.WriteLine(Item)
	Next
	oWrite.Close()
End Sub
