lisp AutoCAD __to__ Inventor
hosneyalaa
Advisor Advisor
Message 1 of 1
hosneyalaa
(defun C:test_Inventor (/
                           *ACTIVEIDC*
                           *INVENTAPP*
                           *INVENTDCS*
  (vl-load-com)
  (if (setq
        *InventApp*
         (vlax-get-or-create-object "Inventor.Application")
      ) ;_ end of setq
    (progn
      (if (= :vlax-false (vlax-get-property *InventApp* 'Visible))
        (vlax-put-property *InventApp* 'Visible :vlax-true)
      ) ;_ end of if
      (vlax-put-property *InventApp* 'SilentOperation :vlax-true)
      (setq
        *InventDcs*
         (vlax-get-property *InventApp* 'Documents)
      ) ;_ end of setq
      (setq *ActiveIDc*
             (vlax-invoke-method
               *InventDcs* 'Add 12290 "" :vlax-true) ;_ end of vlax-invoke-method
      ) ;_ end of setq
      (alert  (strcat "\nInventor.Application: name Document " (vlax-get-property *ActiveIDc* 'displayName))
      ) ;_ end of alert
    ) ;_ end of progn
  ) ;_ end of if
 ;_ end of if
  (princ)
) ;_ end of defun
;|«Visual LISP© Format Options»
(72 2 50 2 T "end of " 60 9 1 0 0 nil T nil T)
;*** DO NOT add text below the comment! ***|;
Replies (0)
