LineSegment2d.IntersectWithCurve with drawing dimensions
tfrohe_LSI
tfrohe_LSI
I am trying to identify dimensions in my Inventor Drawing that have crossing dimension lines or extension lines.
I am getting the dimension line and extension lines with
Dim oFirstDimLine As LineSegment2d = oFirstDimension.DimensionLine
Dim oFirstExtLine1 As LineSegment2d = oFirstDimension.ExtensionLineOne
Dim oFirstExtLine2 As LineSegment2d = oFirstDimension.ExtensionLineTwo
and
Dim oSecondDimLine As LineSegment2d = oSecondDimension.DimensionLine
When attempting to get the intersection, I get no results even though I can see that they are crossing on the drawing.
If oFirstDimLine.IntersectWithCurve(oSecondDimLine) IsNot Nothing And oFirstExtLine1.IntersectWithCurve(oSecondDimLine) IsNot Nothing And oFirstExtLine2.IntersectWithCurve(oSecondDimLine) IsNot Nothing Then
    ' If the extension lines are crossed, display a message box
    MsgBox("Dimension " & oFisrtDimension.Text.Text & " & Dimension " & oSecondDimension.Text.Text & " have crossed extension lines.",,"Crossed")
    oSelectSet.Select(oFirstDimension)
    oSelectSet.Select(oSecondDimension)
LineSegment2d.IntersectWithCurve takes a curve as input that can be another LineSegment2d so why isn't this working for me?
LineSegment2d.IntersectWithCurve( Curve As Object, [Tolerance] As Double ) As ObjectsEnumerator
CurveObjectInput object. This can be a Line2d, LineSegment2d, Arc2d, EllipticalArc2d, Circle2d, EllipseFull2d, or a BSplineCurve2d.
Thank you.
richterBKSAC
the first thing that's not clear to me is which dimension is "one" and which is "two" in your example?
I assume you're using two nested for-loops to test every dimension against the others?
As far as I can tell your code works, but the mistake is in your if-statement because it is always false.
The IntersectWithCurve method "Returns Nothing if the curves overlap or are parallel.". In this case both dimensionlines are parallel and the method will return Nothing.
If oFirstExtLine1.IntersectWithCurve(oSecondDimLine) IsNot Nothing And oFirstExtLine2.IntersectWithCurve(oSecondDimLine) IsNot Nothing Then
This code works but only in the special case when both extensionlines cross the dimensionline.
best regards,
Matthias
tfrohe_LSI
Thank you Matthias, this helps.
J-Camper
@tfrohe_LSI,
Here is a quick Function i wrote to tell you if 2 input linear dimensions intersect.  It you need to know which entities are intersection, that would be different. Here is the sample:
Sub Main
	Dim dDoc As DrawingDocument = TryCast(ThisApplication.ActiveDocument, DrawingDocument)
	If IsNothing(dDoc) Then Logger.Debug("Not Run In Drawing Document") : Exit Sub
	Dim PickThis1 As LinearGeneralDimension = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "Select Linear Dimension")
	If IsNothing(PickThis1) Then Exit Sub ' If nothing gets selected then we're done
	Dim PickThis2 As LinearGeneralDimension = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "Select Linear Dimension")
	If IsNothing(PickThis2) Then Exit Sub ' If nothing gets selected then we're done
	Logger.Trace("Do they intersect? " & AreDimensionsInterseting(PickThis1, PickThis2))
End Sub
Function AreDimensionsInterseting(oFirstDimension As LinearGeneralDimension, oSecondDimension As LinearGeneralDimension) As Boolean
	Dim FirstLineSegmentList, SecondLineSegmentList As New List(Of LineSegment2d)
	FirstLineSegmentList.Add(oFirstDimension.DimensionLine)
	FirstLineSegmentList.Add(oFirstDimension.ExtensionLineOne)
	FirstLineSegmentList.Add(oFirstDimension.ExtensionLineTwo)
	SecondLineSegmentList.Add(oSecondDimension.DimensionLine)
	SecondLineSegmentList.Add(oSecondDimension.ExtensionLineOne)
	SecondLineSegmentList.Add(oSecondDimension.ExtensionLineTwo)
	For Each TestLineSegment As LineSegment2d In FirstLineSegmentList
		For Each innerTestLineSegment As LineSegment2d In SecondLineSegmentList
			If IsNothing(TestLineSegment.IntersectWithCurve(innerTestLineSegment)) Then Continue For
			Return True
		Next
	Next
	Return False
End Function
tfrohe_LSI
Here is what I have come up with after @richterBKSAC's comments. This works for my purposes but is a little clunky.
Sub Main()
    ' Get the active document
    Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
	' Setup a SelectSet to highlight any crossed dimensions
	Dim oSelectSet As SelectSet = oDoc.SelectSet
	oSelectSet.Clear
	'Setup boolean for crossed dim
	Dim crossed As Boolean = False
    ' Get all the dimensions in the document
    Dim oDims As Inventor.DrawingDimensions = oDoc.ActiveSheet.DrawingDimensions
    ' Loop through each dimension and check if it's an aligned or vertical dimension
    For Each oFirstDimension As DrawingDimension In oDims
		'Exclude dimensiosn that may not have 2 extension lines (ExtensionLineOne, ExtensionLineTwo) or DimensionType Property
		'Will be added later
		If oFirstDimension.Type = kOrdinateDimensionObject Or oFirstDimension.Type = kRadiusGeneralDimensionObject Or oFirstDimension.Type = kDiameterGeneralDimensionObject Or oFirstDimension.Type = kAngularGeneralDimensionObject Then Continue For
		'MsgBox(oFirstDimension.Type,,"test")
		Try
	        'MsgBox("First Dimension Type is: " & oFirstDimension.Type,,"iLogic")
	        ' Check if it's an aligned, horizontal or vertical dimension
	        If oFirstDimension.DimensionType = DimensionTypeEnum.kAlignedDimensionType Or oFirstDimension.DimensionType = DimensionTypeEnum.kVerticalDimensionType Or oFirstDimension.DimensionType = DimensionTypeEnum.kHorizontalDimensionType Then
	            ' Get the dimension and extension lines for the first dimension
				' Loop through all drawing dimensions to compare if any lines are crossed
				For Each oSecondDimension As DrawingDimension In oDims
					'MsgBox("Second Dimension Type is: " & oSecondDimension.Type,,"iLogic")
					'Do not check the dimensions if they are the same
		            If oSecondDimension Is oFirstDimension Then Continue For
					If oSecondDimension.Type = kOrdinateDimensionObject Or oSecondDimension.Type = kRadiusGeneralDimensionObject Or oSecondDimension.Type = kDiameterGeneralDimensionObject Or oSecondDimension.Type = kAngularGeneralDimensionObject Then Continue For
						' Check if it's an aligned, horizonal or vertical dimension
	        			If oSecondDimension.DimensionType = DimensionTypeEnum.kAlignedDimensionType Or oSecondDimension.DimensionType = DimensionTypeEnum.kVerticalDimensionType Or oSecondDimension.DimensionType = DimensionTypeEnum.kHorizontalDimensionType Then
							' Get the dimnesion line for the dimension
							' Check if the dimension lines are crossing
							Dim oDimLineIntersect As ObjectsEnumerator  = oFirstDimLine.IntersectWithCurve(oSecondDimLine)
							Dim oExtLine1Intersect As ObjectsEnumerator  = oFirstExtLine1.IntersectWithCurve(oSecondDimLine)
							Dim oExtLine2Intersect As ObjectsEnumerator = oFirstExtLine2.IntersectWithCurve(oSecondDimLine)
							'For our purposes, if crossing points are at the StartPoint or EndPoint of a dimension line, they are not counted as crossing
		            		If oDimLineIntersect IsNot Nothing Then
								For Each oPoint As Point2d In oDimLineIntersect
									If Not (oPoint.IsEqualTo(oSecondDimLine.StartPoint) Or oPoint.IsEqualTo(oSecondDimLine.EndPoint)) Then
										crossed = True
								Next
							If oExtLine1Intersect IsNot Nothing Then
								For Each oPoint As Point2d In oExtLine1Intersect
										crossed = True
								Next
							If oExtLine2Intersect IsNot Nothing Then
								For Each oPoint As Point2d In oExtLine2Intersect
										crossed = True
								Next
							' If the dimension/extension lines are crossed, display a message box and add them to the selection set
							If crossed Then
		                		MsgBox("Dimension " & oFirstDimension.Text.Text & " & Dimension " & oSecondDimension.Text.Text & " have crossed extension lines.",,"Crossed")
								crossed = False
	            Next
    	Catch ex As Exception
			MsgBox(ex.Message)
		End Try
	Next
End Sub
I plan to revise this to add additional dimension types in the future.
@J-Camper I did try your code and it works fine. I have marked it as a solution although I have not used it in my script. Thank you.
ashik_rahmanPXGR8
Did you get a chance to work on this further to add more dimension type?
