LineGraphics.LineWeight capped to 4 px
FRFR1426
FRFR1426
The following code should draw a 1 cm width line:
Public Sub MyLine()
    Dim clientId As String
    clientId = "{2E2EA04D-C12D-4280-BAE3-8ED9DC7DFFA0}"
    Dim graphics As ClientGraphics
    On Error Resume Next
    ThisDocument.ComponentDefinition.ClientGraphicsCollection(clientId).Delete
    On Error GoTo 0
    Set graphics = ThisDocument.ComponentDefinition.ClientGraphicsCollection.Add(clientId)
    Dim node As GraphicsNode
    Set node = graphics.AddNode(1)
    ThisDocument.GraphicsDataSetsCollection(clientId).Delete
    On Error GoTo 0
    Dim dataSets As GraphicsDataSets
    Set dataSets = ThisDocument.GraphicsDataSetsCollection.Add(clientId)
    Dim coordSet As GraphicsCoordinateSet
    Set coordSet = dataSets.CreateCoordinateSet(1)
    Dim coords(5) As Double
    coords(0) = 0: coords(1) = 0: coords(2) = 0: coords(3) = 1: coords(4) = 1: coords(5) = 1
    coordSet.PutCoordinates coords
    Dim lineGraphPrimitive As LineGraphics
    Set lineGraphPrimitive = node.AddLineGraphics()
    lineGraphPrimitive.LineWeight = 1
    lineGraphPrimitive.LineDefinitionSpace = kModelSpace
    lineGraphPrimitive.CoordinateSet = coordSet
    ThisDocument.Views(1).Update
End Sub
But the LineWeight is not taken in account. In fact, even with LineDefinitionSpace at kScreenSpace, the line weight does not always match the value set. It seems that the line weight is capped to 4 px.
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Maxence,
There is a huge difference between kScreenSpace and kModelSpace of LineDefinitionSpace.
If LineDefinitionSpace is set to kScreenSpace, mentioned LineWeight would be in pixels. So, it is completely depends on resolution of screen (Displaying Monitor). More the resolution of screen, visibility of line would be smaller for the same LineWeight and vice versa.
If LineDefinitionSpace is set to kModelSpace, mentioned LineWeight would in default / model units (Centimeters). It does not vary at all on resolution of screen.
For this reason, LineWeight is showing difference for kScreenSpace and kModelSpace. Meanwhile, the visibility of line graphics also differs.
Please feel free to contact if there is any doubt.
If solves your problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
FRFR1426
If I use kModelSpace, when I zoom in, the line should be thicker. It's how I understand model space.
What you're telling me for kModelSpace is the definition of device-independent pixels. And if I increase the value in kScreenSpace or in kModelSpace, the line should be thicker on screen. It does not go further than 4 px.
Maxence DELANNOY
Manager
http://wiip.fr
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Maxence,
Please find the following VBA code with 2 lines having different line weights. After running this code, lines will have different thickness as shown below.
This shows that on increasing line weight in kScreenSpace, thickness also increases.
Sub main()
    clientId = "2E2EA04D-C12D-4280-BAE3-8ED9DC7DFFA0"
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim compDef As PartComponentDefinition
    Set compDef = oDoc.ComponentDefinition
    compDef.ClientGraphicsCollection(clientId).Delete
    On Error GoTo 0
    Set graphics = compDef.ClientGraphicsCollection.Add(clientId)
    oDoc.GraphicsDataSetsCollection(clientId).Delete
    On Error GoTo 0
    Set dataSets = oDoc.GraphicsDataSetsCollection.Add(clientId)
    lineGraphPrimitive.LineWeight = 4
    lineGraphPrimitive.LineDefinitionSpace = kScreenSpace
    Dim coordSet1 As GraphicsCoordinateSet
    Set coordSet1 = dataSets.CreateCoordinateSet(2)
    Dim coords1(5) As Double
    coords1(0) = 1: coords1(1) = 1: coords1(2) = 1: coords1(3) = 2: coords1(4) = 1: coords1(5) = 1
    coordSet1.PutCoordinates coords1
    Dim lineGraphPrimitive1 As LineGraphics
    Set lineGraphPrimitive1 = node.AddLineGraphics()
    lineGraphPrimitive1.LineWeight = 6
    lineGraphPrimitive1.LineDefinitionSpace = kScreenSpace
    lineGraphPrimitive1.CoordinateSet = coordSet1
    Call ThisApplication.Views.Item(1).Update
    Call ThisApplication.ActiveView.Fit
End Sub
If solves your problem, click on "Accept as solution" / give a "kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
FRFR1426
I've taken your code and I've only changed the coordinates in order to align the lines.
2 px & 4 px: OK
4 px & 8 px : I don't get the expected result. The 8 px line stays at 4 px:
And with kModelSpace, always 4px, LineWeight has no effect:
There is also kHybridSpace: always 2px wide...
Maxence DELANNOY
Manager
http://wiip.fr
FRFR1426
I'm gonna do draw my thick lines myself with triangle primitives.
Maxence DELANNOY
Manager
http://wiip.fr
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Maxence,
That's nice idea!!!!
Inventor, Line weight of Line Graphics is limited from 1 px to 4 px.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
