Limit duration time of external iLocic rule execution
Maxim-CADman77
Advisor Advisor
Message 1 of 13
Maxim-CADman77
I've created a set of iLogic rules for checking Inventor documents against local corporate standards and a single aggregator iLogic rule which initiate run of rules and collect check results in a kind of a report.
But execution of some rules on some documents may take quite a long time which I like to prevent.
AFAIK iLogic rule can't abort itself according to some given duration time limit, right?
I'd like to know whether parent (aggregator) iLogic rule can abort execution of its child iLogic if it is running longer than it is allowed (and if yes then how)?
Thanks in advance.
Please vote for Inventor-Idea Text Search within Option Names
Replies (12)
Message 2 of 13
Maxim-CADman77
Not possible?
Message 3 of 13
JaneFan
As I know, it is not supported in iLogic to abort the rule execution in parent rule, either.
Jane Fan
Inventor/Fusion QA Engineer
Message 4 of 13
MjDeck
iLogic doesn't provide functions or UI to make this easy to do. But you can add code to a rule to make it end after a specified time. Here's a sample:
Dim startTime = Now
For i = 1 To 10
	Threading.Thread.Sleep(1000)
	Dim timeDiff As TimeSpan = Now - startTime
	If timeDiff.TotalSeconds > 5 Then
		MessageBox.Show("Time is up", "Check")
		Return ' Exit the rule
Next
Mike Deck
Software Developer
Autodesk, Inc.
Message 5 of 13
DRoam
From your parent rule you can create a Shared Variable for the timeout time. Each for your child rules can check, at various checkpoints, if "now" is greater than the timeout time. If it is, they can exit. In your parent rule, you'll also want to check between each child rule, so it can stop running subsequent rules. Overall, this might look something like this:
Parent rule:
(EDIT: I edited this so that it will remove the shared timeout variable before a timeout exit)
Sub Main()
Dim oTimeout As DateTime = Now.AddSeconds(60)
SharedVariable("Timeout") = oTimeout
iLogicVb.RunExternalRule("Rule1")
If TimeExpired Then Goto MyExit
iLogicVb.RunExternalRule("Rule2")
iLogicVb.RunExternalRule("Rule3")
MyExit:
SharedVariable.Remove("Timeout")
Return
End Sub
Function TimeExpired As Boolean
	If SharedVariable.Exists("Timeout") Then
		Return ( Now > SharedVariable("Timeout") )
	Else
		Return False
End Function
Child rules:
Sub Main()
For i = 1 To TaskCount
	If TimeExpired Then Return
	'Do task
Next
End Sub
	Else
		Return False
End Function
Message 6 of 13
DRoam
You could also try using a progress bar with a cancel button. I think this would work, but it would only be able to bail out from the parent rule, between each child rule. It wouldn't be able to stop operation within a child rule. You could try this and see how it works for you:
(If you run this as-is you can see a sample of how it works).
Sub Main()
'~~~~~Progresss bar setup~~~~~
Dim oTitle As String = "Progress Bar Title"
Dim OpsCount As Integer = 9 '<--- CHANGE TO YOUR # OF CHILD RULES BEING FIRED
Dim oDebugDelay As Integer = 1000 '<--- CHANGE TO ZERO WHEN TESTING WITH YOUR CHILD RULES
'~~~~~Initiate progress bar~~~~~
TotalOpsCount = OpsCount + 1 'Adds "Finishing..." operation
Dim oProgressBar As Inventor.ProgressBar = ThisApplication.CreateProgressBar(False,TotalOpsCount,oTitle,True)
	AddHandler oProgressBar.OnCancel, AddressOf ProgressBarCancel
	CurrentOp = -1
	ContinueProcess = True
	ProgressBarUpdate(oProgressBar,"Loading...",oDebugDelay)
	'~~~~~~~~~~~~~Replace this:~~~~~~~~~~~~~
	For i = 1 To TotalOpsCount - 1
		If ContinueProcess = False Then Exit For
		ProgressBarUpdate(oProgressBar,"Processing...",oDebugDelay)
	Next
	'~~~~~...with something like this:~~~~~~
'	iLogicVb.RunExternalRule("Rule1")
'	If ContinueProcess = False Then Goto MyExit
'	iLogicVb.RunExternalRule("Rule2")
'	iLogicVb.RunExternalRule("Rule3")
	MyExit:
	ProgressBarUpdate(oProgressBar,"Finishing...",oDebugDelay)
oProgressBar.Close
End Sub
Private ContinueProcess As Boolean
Private CurrentOp As Integer
Private TotalOpsCount As Integer
Sub ProgressBarUpdate(oProgressBar As Inventor.ProgressBar, oMessage As String,Optional oDebugDelay As Integer = 0)
	CurrentOp = CurrentOp + 1
	Dim PercentComplete As Integer = CurrentOp/(TotalOpsCount) * 100
	oProgressBar.Message = oMessage & vbCrLf & "Percent complete: " & PercentComplete & "%"
	oProgressBar.UpdateProgress
	System.Threading.Thread.Sleep(oDebugDelay)
End Sub 'Progress bar update
Sub ProgressBarCancel
	MessageBox.Show("Process cancelled.","",MessageBoxButtons.OK,MessageBoxIcon.Exclamation)
End Sub
Message 7 of 13
Maxim-CADman77
Thank you for the idea but I don't see how can I apply it on a check like this
Dim stopWatch As New Stopwatch()
stopWatch.Start()
Dim res_status As String="PASS"
Dim oSB As SurfaceBody=ThisDoc.Document.ComponentDefinition.SurfaceBodies(1)
If Not oSB.IsEntityValid(oSB.FaceShells(1), 5, pr) Then res_status="FAIL"
stopWatch.Stop()
Dim ts As TimeSpan=stopWatch.Elapsed
Dim elapsedTime As String = String.Format("{0:00}:{1:00}:{2:00}.{3:00}", ts.Hours, ts.Minutes, ts.Seconds, ts.Milliseconds / 10)
MsgBox(res_status ,,"Duration Time:"& elapsedTime)
Which being run on the 3D like attached lasts for about 1-2 minutes depending on the PC configuration.
Is it possible to break it let say after 15 seconds?
Message 8 of 13
DRoam
I don't think we have the ability to interrupt iLogic mid-execution of an operation (single line). Mike may know of one, but I don't.
But if you're doing this operation multiple times, then you can use the progress bar and you should be able to cancel between operations by checking the "ContinueOperation" boolean between each operation. But it'll always have to finish executing the current line before it can respond to the cancel event. So if it takes 2 minutes to execute the IsEntityValid line, you'll just have to wait 2 minutes for it to cancel. But at least it won't keep going after that.
Doesn't help you much now, but you could also vote for this functionality request: ESC key stop iLogic Script.
Message 9 of 13
DRoam
Another thing you could do is, if you know certain parts will be a problem, create a boolean iProperty in them called something like "SkipDuringCheck" and set it to True. Then have your iLogic code check for this before processing each part.
You could even have your iLogic automatically set this to True if it takes more than 15 seconds to process a part. That way, any "heavy" parts you missed tagging manually will be processed once, but never again.
This would also give you a good way to scroll through the BOM and see which parts are marked as "Skip" and therefore not being processed by your rule.
Message 10 of 13
MjDeck
I found that you can get the IsEntityValid check on that sample part (B119RQ11111(LongTopoCheck)) to run instantaneously by "re-making" the coil feature. Rebuild All isn't sufficient. But this is: edit the feature and change the Coil Size > Revolution to 5.1 ul. Then change it back to 5.0.
Mike Deck
Software Developer
Autodesk, Inc.
Message 11 of 13
Maxim-CADman77
Mike,
I do confirm that after "refreshing" the sample model* with changing the parameter twice the topology check** returns FAIL pretty fast (>0,2sec) ...
BUT
I'm searching some general solution (total check of the company's Vault content reveals considerable check delays on Inventor documents of different types with a batch of checks I've created).
For example I do have a sample of a IAM where check of positional representation lasts for about 4 minutes (because of the fact that each of the two PosRep activation takes about 2 minutes).
Thus if there is any way to break single line of iLogic I'd like to know about it.
Anyway thank you for debugging the IPT.
* In fact the original model is  a bit more complex and was simplified to a single feature by me to be able share it here.
** The real check is also a bit more complex and does contain some cycles. I've simplified it to make it clear that interrupting cycles is not a solution of the issue.
Message 12 of 13
MjDeck
There is currently no way to interrupt a single API or iLogic call.
If you start running checks on all documents but then you interrupt the process, you'll have missing data. The checks won't be complete. Maybe instead of interrupting, you can run the tests on a dedicated machine and let them go as long as necessary? Also, you could log the results to a file that is flushed often. Then you can open that file to look at the results so far.
Mike Deck
Software Developer
Autodesk, Inc.
Message 13 of 13
Maxim-CADman77
Yeah. I'm already doing it all as you've described.
But I also want the add-in we created (as a replace to the buggy Inventor Design Checker) don't interupt the work process of our designers (it forces check of all explisitly open InvDocs just after open and before save, also if initiated by special button).
For 99,99% of InvDocs check with a batch of our iLogic rules takes 3~5sec (which is ok) but that 0,01% of documents that checks for 15+ seconds annoy designers drastically.
Thats why I've created this thread.
But now I see - the is no miracle... We need to teach how to live with what we have.
