Library from part
Library from part
JoAntt
Library from part
JoAntt
Hi
Trying to get the library name from either a material asset or from the dokument without having to
get the material name from a part and then search thru all libraries to find the name of the library.
Any ideas?
WCrihfield
Hi @JoAntt.  So, if you already have a MaterialAsset object, that object has a property called Parent, which will return an Object, that will either be an AssetLibrary, or a Document.  Which one you get probably depends on if the MaterialAsset is a local copy within the document, or the original from the library.  That Parent property is probably as close as you will come to the route you want.
The whole searching through multiple libraries to find it by its name thing, may not pan out if it is a common name like "Red", because it may be found in multiple libraries.  Also, keep in mind that Assets have both Name and DisplayName properties, and the Name property may not contain the Value you are expecting, but that is the one used by the Item() property when looping through a library by Item.   Also keep in mind that usually a library contains both materials and appearances, or at least they are capable of that.  So, you could actually have the same library as your material library, and for your appearance library.
Wesley Crihfield
(Not an Autodesk Employee)
JoAntt
This is how it turned out.
Its close enough for what im doing, but if someone have a better way please let me know!
         Dim CurrentMat As MaterialAsset = ThePart.ActiveMaterial
            For Each AssLib As AssetLibrary In m_inventorApplication.AssetLibraries
                For Each oMaterial As MaterialAsset In AssLib.MaterialAssets
                    If oMaterial.CategoryName = CurrentMat.CategoryName Then
                        If oMaterial.DisplayName = CurrentMat.DisplayName Then
                            TheLibraryName = AssLib.DisplayName
                Next
            Next
