Leader point to midpoint of curve
NachoShaw
Advisor Advisor
NachoShaw
Hey
I am using this code from the API help file
Dim oDrawDoc As DrawingDocument = Invapp.ActiveDocument
Dim oActiveSheet As Sheet = oDrawDoc.ActiveSheet
Dim oDrawingCurveSegment As DrawingCurveSegment = oDrawDoc.SelectSet.Item(1)
Dim oDrawingCurve As DrawingCurve = oDrawingCurveSegment.Parent
Dim oMidPoint As Point2d = oDrawingCurve.MidPoint
Dim oTG As TransientGeometry = Invapp.TransientGeometry
Dim oLeaderPoints As ObjectCollection = Invapp.TransientObjects.CreateObjectCollection
oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 1.5, oMidPoint.Y))
but when the leader is added, the arrow is not positioned on oMidpoint.X, its positioned on the curve end. The 2nd position of oMidpoint.Y is correct...
Am i missing something? Is there any better Balloon code?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Michael.Navara
You must specify correct geometryIntent object
'Get active drawing
Dim drw As DrawingDocument = ThisDoc.Document
'Get active sheet
Dim sh As Sheet = drw.ActiveSheet
'Get selected drawing curve
Dim curveSegment As DrawingCurveSegment = drw.SelectSet(1)
'Create balloon position point
Dim pt As Point2d = curveSegment.Parent.MidPoint.Copy
pt.TranslateBy(ThisApplication.TransientGeometry.CreateVector2d(1,0))
'Create geometry intent
Dim geomIntent As GeometryIntent
'You need to specify PointIntentEnum.kMidPointIntent
geomIntent = sh.CreateGeometryIntent(curveSegment.Parent, PointIntentEnum.kMidPointIntent)
'Create leader points
Dim leaderPoints As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
leaderPoints.Add(pt)
leaderPoints.Add(geomIntent)
'Create Balloon
sh.Balloons.Add(leaderPoints)
