Now in Inventor drawing you can rotate the Leader Note text, but this also changes the text orientation, is it acceptable for you? You can either use LeaderNote.Rotation or below VBA sample to change the text position:
Sub ChangeLeaderTextOrientation()
Dim oLeaderNote As LeaderNote
Set oLeaderNote = Me.SelectSet(1)
Debug.Print oLeaderNote.Rotation
oLeaderNote.Rotation = 1.57
Dim oPo As Point2d
If oLeaderNote.Leader.HasRootNode Then
If Not (oLeaderNote.Position.IsEqualTo(oLeaderNote.Leader.RootNode.Position, 0.000001)) Then
Set oPo = oLeaderNote.Leader.RootNode.Position
oPo.X = oLeaderNote.Leader.RootNode.Position.X
oPo.Y = oLeaderNote.Leader.RootNode.Position.Y + 0.3
' Change the leader note text position just above the root node
oLeaderNote.Position = oPo
End Sub
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
