Latest Apprentice dll
NachoShaw
Advisor Advisor
NachoShaw
Hi
Where can i find or download the latest InventorApprentice.dll? It doesnt seem to come with Inventor these days or if it does, i cant find it. I downloaded a version of InventorView and referenced the dll from there but ive got a bunch of warnings like this one-
Processing COM reference "InventorApprentice" from path "C:\Program Files\Autodesk\Inventor 2022\Bin\RxApprentice.tlb". At least one of the arguments for 'IRxFileSaveAs._WhereUsed' cannot be marshaled by the runtime marshaler. Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate.
i figured it must be a version issue as i didnt have the warnings on 2019 but in 2021 using the same InventorApprentice reference i do.
im looking for 2021 & 2022
thanks
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
nmunro
NachoShaw
Hi
i had downloaded that and installed it. Im going to remove the reference and use Apprentice from inventor instead 🙂
Nacho
KelvionLicenseManagement
Does somebody know which file and path exactly needs to be added as a reference to visual studio to get access to the Apprentice component? I have installed Inventor View 2021 with Apprentice Server but Visual Studio does not add this as a reference e.g. "C:\Program Files\Autodesk\Inventor View 2021\Bin\Bin32\RxApprentice.tlb"
JelteDeJong
Hi Cornelius,
you need to reference the dll:
C:\Program Files\Autodesk\Inventor 2021\Bin\Public Assemblies\Autodesk.Inventor.Interop.dll
Also, make sure that your "Target platform" is set to "x64" (In your build properties)
I created a small test/example application.
https://github.com/hjalte79/InventorApiTesterApprentice
https://github.com/hjalte79/InventorApiTesterApprentice/blob/master/InventorApiTesterApprentice/Prog...
Jelte de Jong
Blog: hjalte.nl - github.com
Hi Jelte,
the dll I was searching for can be found here:
"C:\Program Files\Autodesk\Inventor View 2021\Bin\RxApprenticeInterop.dll"
You only need an installation of Inventor View(with Apprentice) to get the library.
