- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
l have found this iLogic code to calculate the Laser cut length for our sheetmetal parts. The code works perfectly at part level, l have the event trigger set to "before save document". But when l have the part in an assembly and click save for an updated part, it doesnt update saying the part must be 'active' for this rule to work.
Is there any line of code that l can add to be able to run this rule when l click "save" in the assembly.
If Not TypeOf ThisApplication.ActiveDocument Is PartDocument Then
MsgBox("A Part document must be 'active' for this rule to work. Exiting rule.",,"")
Exit Sub
End If
Dim oPDoc As PartDocument = ThisApplication.ActiveDocument
If Not TypeOf oPDoc.ComponentDefinition Is SheetMetalComponentDefinition Then
MsgBox("This Part is not a Sheet Metal Part. Exiting rule.",,"")
Exit Sub
End If
Dim oSMDef As SheetMetalComponentDefinition = oPDoc.ComponentDefinition
If Not oSMDef.HasFlatPattern Then
oAns = MsgBox("This Sheet Metal Part does not have a Flat Pattern." & vbCrLf & _
"This is needed to calculate 'LaserCutLength'." & vbCrLf & _
"Do you want this rule to automatically create the Flat Pattern, then continue?", vbYesNo + vbQuestion, "")
If oAns = vbNo Then Exit Sub
Try
oSMDef.Unfold
Catch oEx As Exception
MsgBox("Failed to 'Unfold' this Sheet Metal Part, to create a Flat Pattern." & vbCrLf & _
oEx.Message & vbCrLf & oEx.StackTrace, , "")
Exit Sub
End Try
End If
Dim oFP As FlatPattern = oSMDef.FlatPattern
Dim oLengths As New List(Of Double)
For Each oEL As EdgeLoop In oFP.BottomFace.EdgeLoops
oLengths.Add(ThisApplication.MeasureTools.GetLoopLength(oEL))
Next
'a = InputListBox("", oLengths, 0.0, "Loop Lengths", "Individual Loop Lengths")
Dim oParam As UserParameter
Try
oParam = oSMDef.Parameters.UserParameters.Item("Cutting_Distance")
oParam.Value = oLengths.Sum
Catch
oParam = oSMDef.Parameters.UserParameters.AddByValue("Cutting_Distance", oLengths.Sum, "mm")
End Try
iLogicVb.UpdateWhenDone = True
Alex
