JustSelectedEntities Is A Part Occurrance
I'm having a difficult time getting from the selection process to the SaveAs function. I'm using a selection filter "kAssemblyOccurrenceFilter" which allow me to select a part, but I keep getting an invalid cast exception when I try to use my selected part as the original document for my SaveAs.
Private m_Part As Inventor.ComponentOccurrence
m_Part = JustSelectedEntities.Item(0)
Here's where I'm stuck. How do I get my selected object to a SaveAs statement?
Jon
You need to make sure that the guy in JustSelectedEntities is actually a component occurrence. And make sure you're starting your indicies at 1 for Inventor's types.
JustSelectedEntities is an ObjectEnumerator, right?
Try something like this:
{code}
For Each objEntity as Object in JustSelectedEntities
If typeof objEntity Is ComponentOccurrence Then
'Do whatever you need
End if
Next
{code}
If you then want to save that file for the occurrence, you should be able get to it through the ComponentOccurrence.Definition.Document property.
This is what I needed. Thank you.
Jon
