itrigger not working?
tony
tony
Hi, hopefully a simple solution?
During testing of some code "iLogic to Trim a File Name to Populate iProperties" setup by another user (on this page) I found that triggering the code with event triggers caused errors with other software using event triggers.
If i save the open doc and then press the itrigger button the code fails to run unless the Rule is run manually before hand.
Sub Main
trigger=iTrigger0
Dim ThisDocument As PartDocument = ThisApplication.ActiveEditDocument.......
Is placing "trigger=iTrigger0" under the Sub Main correct to manually trigger the code?
Thank you
tony
Sorted, Set event trigger to "Any Parameter change"
