Iterate through whole assembly - trying to build mark numbers
mslosar
Advisor Advisor
mslosar
OK, what I'm trying to do is iterate through an entire assembly and generate mark numbers for parts that are library and/or content center parts. Parts that are read only.
For example - a whole shipping unit with have, say, 4 assemblies (ZR1-300, ZR1-330, ZR5-800, and ZR6-900). In our case, the mark number for each of those is:
ZR1-300-1
ZR1-330-1
ZR5-800-1
ZR6-900-1
Those are no problem. The custom iproperty MARK_NO exists in them and is editable on a per project basis.
Now, there are assorted nuts/bolts associated with each of the 4 sub assemblies. These, being content center part can't have different MARK_NO's per use. Therefore, presently we've been just manually assigned them MARK_NO's but manually editing the part's list. If the bolt is on line 5, for the ZR-300, it's MARK_NO is ZR1-300-5. In the nut was on line 8, ZR1-300-8. Basically, the line of the parts list/BOM equals the mark number.
I used the sample code from the help file below to make the original code:
Public Sub BOMQuery()
    ' Set a reference to the assembly document.
    ' This assumes an assembly document is active.
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim FirstLevelOnly As Boolean
    If MsgBox("First level only?", vbYesNo) = vbYes Then
        FirstLevelOnly = True
    Else
        FirstLevelOnly = False
    ' Set a reference to the BOM
    Dim oBOM As BOM
    Set oBOM = oDoc.ComponentDefinition.BOM
    ' Set whether first level only or all levels.
    If FirstLevelOnly Then
        oBOM.StructuredViewFirstLevelOnly = True
    Else
        oBOM.StructuredViewFirstLevelOnly = False
    ' Make sure that the structured view is enabled.
    oBOM.StructuredViewEnabled = True
    'Set a reference to the "Structured" BOMView
    Dim oBOMView As BOMView
    Set oBOMView = oBOM.BOMViews.Item("Structured")
    Debug.Print "Item"; Tab(15); "Quantity"; Tab(30); "Part Number"; Tab(70); "Description"
    Debug.Print "----------------------------------------------------------------------------------"
    'Initialize the tab for ItemNumber
    Dim ItemTab As Long
    ItemTab = -3
    Call QueryBOMRowProperties(oBOMView.BOMRows, ItemTab)
End Sub
Private Sub QueryBOMRowProperties(oBOMRows As BOMRowsEnumerator, ItemTab As Long)
    ItemTab = ItemTab + 3
    ' Iterate through the contents of the BOM Rows.
    Dim i As Long
    For i = 1 To oBOMRows.Count
        ' Get the current row.
        Dim oRow As BOMRow
        Set oRow = oBOMRows.Item(i)
        'Set a reference to the primary ComponentDefinition of the row
        Dim oCompDef As ComponentDefinition
        Set oCompDef = oRow.ComponentDefinitions.Item(1)
        Dim oPartNumProperty As Property
        Dim oDescripProperty As Property
        If Typeof oCompDef Is VirtualComponentDefinition Then
            'Get the file property that contains the "Part Number"
            'The file property is obtained from the virtual component definition
            Set oPartNumProperty = oCompDef.PropertySets _
                .Item("Design Tracking Properties").Item("Part Number")
            'Get the file property that contains the "Description"
            Set oDescripProperty = oCompDef.PropertySets _
                .Item("Design Tracking Properties").Item("Description")
            Debug.Print Tab(ItemTab); oRow.ItemNumber; Tab(17); oRow.ItemQuantity; Tab(30); _
                oPartNumProperty.Value; Tab(70); oDescripProperty.Value
        Else
            'The file property is obtained from the parent
            'document of the associated ComponentDefinition.
            Set oPartNumProperty = oCompDef.Document.PropertySets _
            Set oDescripProperty = oCompDef.Document.PropertySets _
            'Recursively iterate child rows if present.
            If Not oRow.ChildRows Is Nothing Then
                Call QueryBOMRowProperties(oRow.ChildRows, ItemTab)
    Next
    ItemTab = ItemTab - 3
End Sub
My theoretical solution to being able to add our mark numbers directly to exports was to see if the object had a tag number. If it did, use it. Otherwise it was going to be get the first 8 digits of the parents MARK_NO (ZR1-300-) and then append the BOM's line number to it (ZR1-300-5).
Problem is, i cannot figure out how get the parent from within this code properly. Best I can figure is at the "
line at the end, pull the mark number from the assembly, but this isn't tracking the assembly, just the BOM rows, so that's where I get lost.
Thanks for reading, hope it makes sense and is an easy fix 🙂
woodstylee3
You may find the below code useful, I use it to process a structured bom which is all levels. Rather than resolve the parent from the child, I use an approach of nested function calls where data from the parent is passed as a second parameter to the nested call. If doesn't make sense I can talk you through more..
Hope it helps..
Private Sub export_materials_rough_list() Handles ss_roughcutmatl.OnExecute
Dim ref_doc As AssemblyDocument
ref_doc = GlobalVar.m_inventorApplication.ActiveDocument
If IsNothing(ref_doc) Then Return
Dim excel As Microsoft.Office.Interop.Excel.Application
Dim wkbk As Microsoft.Office.Interop.Excel.Workbook
Try
excel = New Microsoft.Office.Interop.Excel.Application
wkbk = excel.Workbooks.Add
Dim excelwks = wkbk.Worksheets.Add
Dim n() As String = New String() {"Parent Assembly", "PartNumber", "Qty", "Material Spec", "Thickness", "Mass", "Total Mass"}
For x = 0 To 6
If Not (IsNothing(n(x))) Then excelwks.Cells(1, x + 1).value = n(x)
Next
export_materials_rough_list_assy(ref_doc.ComponentDefinition, excelwks, 2, 1, "")
' excelwks.SaveAs()
wkbk.SaveAs(ref_doc.FullFileName & "_Materialisation.xlsx")
excel.Visible = True
Catch ex As Exception
Dim a As Integer = 1
If IsNothing(wkbk) Then
Else
wkbk.close(False)
If IsNothing(excel) Then
Else
excel.Quit()
End Try
End Sub
Private Sub export_materials_rough_list_assy(componentdef As ComponentDefinition, excelwks As Microsoft.Office.Interop.Excel.Worksheet, ByRef ctr As Integer, ByVal baseqty As Integer, ByVal parenttext As String)
Dim bom As Inventor.BOMStructureEnum
Dim m_parent As String
Try
If (CInt(componentdef.Type) = CInt(ObjectTypeEnum.kAssemblyComponentDefinitionObject)) Or (CInt(componentdef.Type) = CInt(ObjectTypeEnum.kWeldmentComponentDefinitionObject)) Then
bom = componentdef.BOMStructure
For Each bomv As Inventor.BOMView In componentdef.BOM.BOMViews
If bomv.ViewType = BOMViewTypeEnum.kStructuredBOMViewType Then
For Each bomrow As Inventor.BOMRow In bomv.BOMRows
Dim process As Boolean
Select Case bomrow.BOMStructure
Case Is = BOMStructureEnum.kVariesBOMStructure
process = True
m_parent = GlobalVar.m_project_file.iprop_mappings.itemfromkey(GlobalVar.m_project_file.Partslist_Settings.PartNumber.PropertyGuid).Read(componentdef.Document)
Case Is = BOMStructureEnum.kInseparableBOMStructure
process = True
Case Is = BOMStructureEnum.kNormalBOMStructure
process = True
Case Is = BOMStructureEnum.kPhantomBOMStructure
process = True
m_parent = parenttext
Case Is = BOMStructureEnum.kPurchasedBOMStructure
process = False
Case Is = BOMStructureEnum.kReferenceBOMStructure
process = False
End Select
If process Then
If bomrow.ComponentDefinitions.Count = 1 Then
export_materials_rough_list_assy(bomrow.ComponentDefinitions(1), excelwks, ctr, baseqty * bomrow.ItemQuantity, m_parent)
Next
Next
ElseIf (CInt(componentdef.Type) = CInt(ObjectTypeEnum.kPartComponentDefinitionObject)) Or (CInt(componentdef.Type) = CInt(ObjectTypeEnum.kSheetMetalComponentDefinitionObject)) Then
Select Case bom
process = True
process = True
process = True
process = False
process = False
End Select
If process Then
Dim n As String()
Try
'''your code here...
n = Nothing
End Try
Dim a As Integer
End Try
End Sub
mslosar
Thanks for the suggestion. I'll dig into it and see what happens 🙂
