Iterate through a BOM and display a quantity for every part
Hi all,
I am trying to write a rule to iterate through a BOM and have the quantity for every part be displayed. So far I have:
	part_number = iProperties.Value("Project", "Part Number")
	pnstr = CStr(part_number)
	quantity = ThisBOM.CalculateQuantity("Model Data", pnstr)
	MessageBox.Show(quantity, "Title")
How can Make this run through and display a quantity value for every part in an assembly?
Ralf_Krieg
Hello
CalculateQuantity sets the quantity of a BOM row from overridden back to automatic calculation. For parts code below could help. If you need quantities of assemblies too, there's much more work to do.
If Not ThisDoc.Document.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
	MsgBox("This rule is for assembly documents",, "iLogic")
	Exit Sub
Dim oAssDoc As AssemblyDocument = ThisDoc.Document
Dim oBom As BOM = oAssDoc.ComponentDefinition.BOM
oBom.PartsOnlyViewEnabled = True
Dim oBomView As BOMView
For Each oBomView In oBom.BOMViews
	If oBomView.Name = "Parts only" Then Exit For
Next
If oBomView Is Nothing Then
	MsgBox("Can not access BOM view",, "iLogic")
	Exit Sub
Dim oBomRow As BOMRow
Dim lQuantity As Long
Dim sPartNumber As String
For Each oBomrow In oBomView.BOMRows
	lQuantity = oBomRow.ItemQuantity
	sPartNumber = oBomRow.ComponentDefinitions(1).Document.propertysets(3).item(2).value
	MsgBox("PNr: " & sPartNumber & vbCrLf & "Qty: " & lQuantity,, "iLogic")
Next
R. Krieg
RKW Solutions
www.rkw-solutions.com
