Item Number Custom Balloons
MrSmithtastic
Message 1 of 1
MrSmithtastic
OK so I thought I'd found what I was looking for. I found this http://cadsetterout.com/inventor-tutorials/autodesk-inventor-creating-coordinated-bom-for-large-asse...
Then I saw in the comments a way to automate it.... But...
The code:
doc = ThisDoc.Document
Dim oAssyDef As AssemblyComponentDefinition = doc.ComponentDefinition
Dim oBOM As BOM = oAssyDef.BOM
oBOM.PartsOnlyViewEnabled = True
Dim oBOMView As BOMView = oBOM.BOMViews.Item("Parts Only")
Dim oBOMRow As BOMRow
For Each oBOMRow In oBOMView.BOMRows
    'Set a reference to the primary ComponentDefinition of the row
    Dim oCompDef As ComponentDefinition
    oCompDef = oBOMRow.ComponentDefinitions.Item(1)
    Dim CompFullDocumentName As String = oCompDef.Document.FullDocumentName
    Dim CompFileNameOnly As String
    Dim index As Integer = CompFullDocumentName.lastindexof("\")
    CompFileNameOnly = CompFullDocumentName.substring(index+1)
    'MessageBox.Show(CompFileNameOnly)
    Dim Qty As String
    Qty = oBOMRow.TotalQuantity
    iProperties.Value(CompFileNameOnly, "Custom", "PartQty") = Qty
Next
... when edited to say #ITEM and ItemNumber etc doesn't quite work.
I have some iparts and it doesn't push the item number to the parts.. So I looked again.
I found this code:
Dim openDoc As Document
openDoc = ThisDoc.Document
Dim docFile As Document
If openDoc.DocumentType = kAssemblyDocumentObject Then
	For Each docFile In openDoc.AllReferencedDocuments
		If docFile.IsModifiable = True Then
			Dim assemblyDoc As AssemblyDocument
			assemblyDoc = openDoc
			Dim assemblyDef As AssemblyComponentDefinition
			assemblyDef = assemblyDoc.ComponentDefinition
			Dim partQty As ComponentOccurrencesEnumerator
			partQty = assemblyDef.Occurrences.AllReferencedOccurrences(docFile)
			Dim customPropSet As PropertySet
			Dim customProp As Inventor.Property
			Dim propertyName As String
			Dim propertyValue As Integer
			customPropSet = docFile.PropertySets.Item("Inventor User Defined Properties")
			propertyName = "TotalQty"
			Try
				propertyValue = customPropSet.Item(propertyName).Value
				If PartQty.Count <> propertyValue Then
					customPropSet.Item(propertyName).Value = PartQty.Count
				Catch ex As Exception
				customProp = customPropSet.Add(PartQty.Count, propertyName)
			End Try
	Next
	Else
	MessageBox.Show("You must have a valid Assembly document open before using this code!", "File Type Mismatch!",MessageBoxButtons.OK,MessageBoxIcon.Exclamation)
This time I just ran the code as it came. It pushed the custom property through to every part file! Brilliant!!
Only this time it didn't create the custom iproperty and when I tried to change it to item number it just fell on its face.
I've tried my best to mesh the two codes in the hope of getting it working but I can't figure it.
Here is my mess as it stands:
			Dim oBOM As BOM = assemblyDef.BOM
	Next
			Dim item As ComponentOccurrencesEnumerator
			item = oBOMRow.ItemNumber
			propertyName = "#ITEM"
			Try
					customPropSet.Item(propertyName).Value = item
				customProp = customPropSet.Add(item, propertyName)
			End Try
	Next
	Else
It's not good I know so don't all jump on me.
Is there anyone out there that might be able to get to the bottom of this one for me?
Thanks in advance
Replies (0)
