Hi
your "IF"statements are clear voor a human but a computer will interpret not like you would expext. Your if statments have a couple of faults.
- If you use a "OR" in a "If" statement then the computer will evaluate what is before and afther the "OR" and then evaluate the "OR" statement.
- When a value is converted to an boolean then it is always "True" unless its 0 then its "False".
- x <= y <= z is always "False". i cant explain why.
for exapmle the if statment:
if height = 170 or 210
will always be true because
step 1: if (height = 170) or (210)
step 2: if (False or True) or (True)
step 3: if (true)
as you see beacause the right boolean value is true (step 2) the if statement is always true.
i have simplified your code with this rules in mind and then i get:
If Height <= 168 Or Height = 228 Or Height = 258 Or Height = 345 Or Height = 365 Or Height = 395 Then
h0 = 12
h1 = 12
Else
h0 = 14
h1 = 14
I would advice you to use a "select case" statment. your code would the look more like this:
Dim height = Height
Dim hValue = 0
Select Case Height
Case 0 To 168
hValue = 12
Case 200 To 208
hValue = 12
Case 228
hValue = 12
Case 258
hValue = 12
Case 345
hValue = 12
Case 365
hValue = 12
Case 395
hValue = 12
Case 424 To 424
hValue = 12
' TODO add more cases for hValue = 12 .......
Case 170
hValue = 14
Case 210
hValue = 14
Case 482
hValue = 12
Case 502
hValue = 12
End Select
h0 = hValue
h1 = hValue
i hope that this code explains it self if it does not feel free to ask.
Jelte de Jong
Blog: hjalte.nl - github.com
