Issue with InputBox Cancel Button
bbrumfield
bbrumfield
Any Help would be appreciated.
Trying to clean up some code so that if the user Hits the cancel button rather than inputting a number they will get bounced back to the start, If they were to leave the text field zero the rule below works but if they cancel there is an error :
Width :
Dim dSheetWidth As Double = CInt(InputBox("Enter Material Width (Value Required)", "Sheet Width", 0.00))
If dSheetWidth = 0 Or Nothing
	MessageBox.Show("You Must Enter A Sheet Width")
	GoTo Width
Brent
A.Acheson
This was a little trickier than expected but these two samples seem to work. The cancel and close buttons have a string value where as you have declared a double value. Sample 1 sends the string error to a double value which luckily you don't need to use a value of 0. Sample 2 handles the string values first then the double values.
Here is a link to sample1
Width :
On Error Resume Next
On Error GoTo 0 'Error handling
If dSheetWidth = 0 Then GoTo Width
	MessageBox.Show(dSheetWidth, "Success")
Here is a link to sample2
Width :
Dim sSheetWidth As String = InputBox("Enter Material Width (Value Required)", "Sheet Width", 0.00)
If sSheetWidth = vbNullString Then : GoTo Width 'Deal with cancel/close button
ElseIf sSheetWidth <> vbNullString And Not IsNumeric(sSheetWidth)Then : GoTo Width 'Deal with non numeric values
ElseIf sSheetWidth <> vbNullString And IsNumeric(sSheetWidth)Then 'Is a valid double entry
	dSheetWidth = CInt(sSheetWidth)
	If dSheetWidth = 0 Then : GoTo Width
	Else
Regards
Alan
Curtis_W
Hi @bbrumfield
With iLogic, you can put the inputbox in a try/catch to handle the cancel button.
I hope this helps.
Curtis
Try
	dSheetWidth = CInt(InputBox("Enter Material Width (Value Required)", "Sheet Width", 0.00))
Catch
	dSheetWidth = 0
End Try
If dSheetWidth = 0
	GoTo Width
bbrumfield
Hi Curtis,
Thank you! This has solved the Cancel button issue.
Brent
bbrumfield
Hi A.Acheson,
Thank you! Both examples work without error.
Brent
