Issue converting VBA into VB.NET
MattH_Test
MattH_Test
The following code work as expected in VBA
Public Sub SetOccurrenceAppearance()
    Dim asmDoc As AssemblyDocument
    Set asmDoc = ThisApplication.ActiveDocument
    ' Get an appearance from the document.  To assign an appearance is must
    ' exist in the document.  This looks for a local appearance and if that
    ' fails it copies the appearance from a library to the document.
    Dim localAsset As Asset
    On Error Resume Next
    Set localAsset = asmDoc.Assets.Item("Bamboo")
    If Err Then
        On Error GoTo 0
        ' Failed to get the appearance in the document, so import it.
        ' Get an asset library by name.  Either the displayed name (which
        ' can changed based on the current language) or the internal name
        ' (which is always the same) can be used.
        Dim assetLib As AssetLibrary
        Set assetLib = ThisApplication.AssetLibraries.Item("Autodesk Appearance Library")
        'Set assetLib = ThisApplication.AssetLibraries.Item("314DE259-5443-4621-BFBD-1730C6CC9AE9")
        ' Get an asset in the library.  Again, either the displayed name or the internal
        ' name can be used.
        Dim libAsset As Asset
        Set libAsset = assetLib.AppearanceAssets.Item("Bamboo")
        'Set libAsset = assetLib.AppearanceAssets.Item("ACADGen-082")
        ' Copy the asset locally.
        Set localAsset = libAsset.CopyTo(asmDoc)
    On Error GoTo 0
    ' Have an occurrence selected.
    Dim occ As ComponentOccurrence
    Set occ = ThisApplication.CommandManager.Pick(kAssemblyOccurrenceFilter, "Select an occurrence.")
    ' Assign the asset to the occurrence.
    occ.appearance = localAsset
End Sub
It should be a simple process to convert it into VB.NET code. I would expect to be able to change
ThisApplication.xxx into oapp.xxx etc
Dim assetLib As AssetLibrary into Dim assetLib As Inventor.AssetLibrary
But VB.NET does not recognize it ( Inventor.AssetLibrary ). Am I making a school boy error and missing something that's right in front of me?
Help!
Cheers
MattH
MattH_Test
30 seconds after posting, solved it myself!!!
in a shortened form
 ''    Dim assetLib As .AssetLibrary  > this line is not needed
        For i = 1 To oApp.AssetLibraries.count
            CmbBx_Libraries.Items.Add(oApp.AssetLibraries.Item(i).displayname)
        Next i
MattH
