Is there any iLogic Code can get ModelName from existed General Table?
ngdnam88
ngdnam88
Dears,
Please help me, I'm looking for an iLogic Code can get the ModelName that used in the General Table:
Thanks you very much!
A.Acheson
Very simple example shown in this post. Here is the API help for the Custom table object
Regards
Alan
ngdnam88
Thanks @A.Acheson
But seem my question is not clear. I mean the iLogic Code can get the ModelName that used for this table (When I run the iLogic rule, it'll return the name of Model Reference) - Not need access cell's value in the General Table.
I know some code that can get ModelDocument in the Drawing, and ModelDocument in the View but didn't found one for General Table,
Michael.Navara
You can try this snippet
Dim drw As DrawingDocument = ThisDoc.Document
Dim table As CustomTable = drw.ActiveSheet.CustomTables(1)
If table.ReferencedDocumentDescriptor Is Nothing Then
	Logger.Warn("Table has no referenced document")
	Return
Dim docDescriptor = TryCast(table.ReferencedDocumentDescriptor, DocumentDescriptor)
If docDescriptor IsNot Nothing Then
	Logger.Info(docDescriptor.FullDocumentName)
	Return
Dim fileDescriptor = TryCast(table.ReferencedDocumentDescriptor, FileDescriptor)
If fileDescriptor IsNot Nothing Then
	Logger.Info(fileDescriptor.FullFileName)
	Return
ngdnam88
Thanks @Michael.Navara ,
Your Code is working perfectly. I got the error when using Logger.Info() - Maybe my Inventor version is not support iLogic Logging.
I replaced by MessageBox.Show() and all code are working in the correct.
