Is there a way to control text Stretch(%)? Trying to automate number plates
Preston_Reed
Message 1 of 10
Preston_Reed
Hello, im trying to automate the creation of number plates based off of an excel sheet of names.  I have it working well, it will make a new part, insert the new text and save it.  The only issue, well I just want it to look a little better truly, but I would like to be able to control the text stretch.  Some of the text is longer than others so I have it set at 150% stretch in order to fit the largest plate.
Replies (9)
Message 2 of 10
Andrii_Humeniuk
Hi @Preston_Reed . First, make sure that the sketch in which the TextBox is located is called "Sketch2" (line 2) and edit it if necessary. In line 3, the program takes the first TextBox in the sketch. Lines 5-12 are a selection based on the number of characters in the text. You need to scale the text to different number of characters according to your situation, I chose the scale arbitrarily.
Dim oDoc As PartDocument = ThisDoc.Document
Dim oSketch As PlanarSketch = oDoc.ComponentDefinition.Sketches("Sketch2")
Dim oText As Inventor.TextBox = oSketch.TextBoxes(1)
Dim oBox As Box2d = oText.RangeBox
Select Case oText.Text.Length
Case 10 : oText.WidthScale = 1.2
Case 11 : oText.WidthScale = 1.3
Case 12 : oText.WidthScale = 1.4
Case 13 : oText.WidthScale = 1.5
Case 14 : oText.WidthScale = 1.6
Case 15 : oText.WidthScale = 1.7
End Select
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Message 3 of 10
gerrardhickson
Yeah - looks like you adjust the 'widthscale' property.
Sub TextStretch()
Dim oD As PartDocument
Dim oS As PlanarSketch
Dim oT As TextBox
Set oD = ThisApplication.ActiveDocument
Set oS = oD.ComponentDefinition.Sketches(1)
Set oT = oS.TextBoxes(1)
oT.WidthScale = 0.5
End Sub
Message 4 of 10
Preston_Reed
Hey im getting error messages trying to access .Sketches from the assembly document, i was looking in the API object model, i dont think i can access sketches from the assembly.
Private Sub CopyPipes()
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oSketch As PlanarSketch = oDoc.AssemblyComponentDefinition.Sketches("TextSketch")    '***Line 33
GoExcel.Open(FileLocation, "Sheet1")
Dim i As Integer = 0
'index Row 2 through 10000
For rowPN = 3 To 100
'find first empty cell in column A
 If GoExcel.CellValue("P:\MCI-METAL RACK\SHEET METAL RACK LABELS.xlsx", "Sheet1", "A1") = "" Then
'create a variable for the cell value that is one row less than the empty cell row
    lastPN = GoExcel.CellValue("P:\MCI-METAL RACK\SHEET METAL RACK LABELS.xlsx", "Sheet1", "A" & rowPN - 1)
		If lastPN.Length() = 9 Then
			oText.WidthScale = 2
		ElseIf lastPN.Length() = 10 Then
			oText.WidthScale = 1.9
		ElseIf lastPN.Length() = 11 Then
			oText.WidthScale = 1.8
		ElseIf lastPN.Length() = 12 Then
		ElseIf lastPN.Length() = 13 Then
		If lastPN = "" Then
        	Exit For
 Parameter("OrginalPart:1", "Text") = lastPN
 oDoc.SaveAs("P:\MCI-METAL RACK\Parts" & "/" & lastPN & ".ipt", True)
Next
End Sub
Message 5 of 10
Frederick_Law
Program is not magic.
It just repeat what you manually do, with more detail usually.
So how would you edit a sketch of a part in an assembly?
Message 6 of 10
Preston_Reed
Well its an assembly file with only 1 part file in it.  The goal is to duplicate that part & replace the text every iteration based off of an excel chart.  I have all of that works just fine, I'm trying to add the ability to control the stretch of the text based off of the string length.
This works code works just fine for what I'm trying to do.  Just trying to add the ability to control stretch now.  When i try to access PlanarSketch via part document i get an error & same with assembly document.  I'm just not sure why i cant access it via part document, it should be there, maybe my syntax is wrong
Sub main
'	MakeParameters
	SetParameters
	CopyPipes
	RuleParametersOutput()
	iLogicVb.DocumentUpdate()
End Sub
Sub MakeParameters
	oMyParameter=ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
	'Setting an userParameter as text parameter
	oParameter=oMyParameter.AddByValue("FileLocation", "", UnitsTypeEnum.kTextUnits)
End Sub
Sub SetParameters
	'Promt the user for the value of a variable
	Input1 = InputBox("FileLocation", "FileLocation: ", "")
	'assign the value of that variable to user parameter
	Parameter.UpdateAfterChange = True
	Parameter("FileLocation") = ""
	Parameter("FileLocation") = Input1
End Sub
Dim oPart = Component.InventorComponent("OrginalPart:1")
Dim oPartDoc As PartDocument = oPart.Definition.Document
Dim oPath As String = ThisDoc.Path
For rowPN = 3 To 1000
		If lastPN = "" Then
        	Exit For
 oPartDoc.SaveAs("P:\MCI-METAL RACK\Parts" & "/" & lastPN & ".ipt", True)
Next
End Sub
Message 7 of 10
Frederick_Law
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-D54193DE-A29F-4336-B266-F2F14410E11C
Usually it's difficult to find what you need in API.
Sometime I use VBA.
Set breakpoint, add Watch and go through objects to find what I need.
Message 8 of 10
gerrardhickson
I agree with @Frederick_Law. Debug it in VBA and then migrate it to .Net once it's working.
There's a few odd things in your code. Make sure your defining everything fully. oPart appears to be a componentoccurrence, but it's not defined as such.
In your CopyPipes() Sub, it looks like oSketch is an assembly level sketch, not a part level sketch which would cause odd behaviour.
If you can share the full code and a sample file it should be easy enough to diagnose.
Message 9 of 10
Andrii_Humeniuk
Hi @Preston_Reed . Check that the names and paths are correct in lines 8, 11-12, 28, 33, 40, 50. The rule should be run in your assembly, then select your excel and finally you will get your details.
Sub main
	Dim oInvApp As Inventor.Application = ThisApplication
	Dim oDoc As Document = oInvApp.ActiveDocument
	If Not TypeOf oDoc Is AssemblyDocument Then Exit Sub
	Dim oAsmDoc As AssemblyDocument = oDoc
	Dim oAsmDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
	Dim oPart As ComponentOccurrence
	Try : oPart = oAsmDef.Occurrences.ItemByName("OrginalPart:1") : Catch : Exit Sub : End Try
	Dim oUParams As UserParameters = oAsmDef.Parameters.UserParameters
	Dim oParam As UserParameter
	Try : oParam = oUParams("FileLocation") : Catch
	oParam = oUParams.AddByValue("FileLocation", "", UnitsTypeEnum.kTextUnits) : End Try
	oParam.Value = GetFileLocation(oInvApp)
	If String.IsNullOrEmpty(oParam.Value) Then Exit Sub
	If Not IO.File.Exists(oParam.Value) Then Exit Sub
	Call CopyPipes(oPart, oParam.Value)
	oDoc.Update()
End Sub
Private Function GetFileLocation(ByVal oInvApp As Inventor.Application) As String
	Dim oFileDlg As Inventor.FileDialog = Nothing: oInvApp.CreateFileDialog(oFileDlg)
	oFileDlg.Filter = "Excel File (*.xlsx;*.xls)|*.xlsx;*.xls"
	oFileDlg.ShowOpen()
	Return oFileDlg.FileName
End Function
Private Function CopyPipes(oPart As ComponentOccurrence, ByVal sFileLoc As String)
	Dim sNameSheet As String = "Sheet1"
	Dim i As Integer = 2
	Dim slastPN, sCellValue As String
	Dim oPartDef As PartComponentDefinition = oPart.Definition
	Dim oPartDoc As PartDocument = oPartDef.Document
	Dim oSketch As PlanarSketch = oPartDef.Sketches("TextSketch")
	GoExcel.Open(sFileLoc, sNameSheet)
	Do
		slastPN = GoExcel.CellValue(sFileLoc, sNameSheet, "A" & i)
		If Not String.IsNullOrEmpty(slastPN) Then
			oPartDef.Parameters.UserParameters("Text").Value = slastPN
			Select Case slastPN.Length()
			Case 9 : oText.WidthScale = 2
			Case 10 : oText.WidthScale = 1.9
			Case 11 : oText.WidthScale = 1.8
			Case 12 : oText.WidthScale = 1.7
			Case 13 : oText.WidthScale = 1.6
			Case 14 : oText.WidthScale = 1.5
			End Select
			oPartDoc.Update()
			oPartDoc.SaveAs("P:\MCI-METAL RACK\Parts\" & slastPN & ".ipt", True)
		i += 1
	Loop While Not String.IsNullOrEmpty(slastPN)
	GoExcel.Close()
End Function
Message 10 of 10
Preston_Reed
@Andrii_Humeniuk thank you so much, it worked perfectly!  I like how you prompted the user to find the location of the file.  I had it as a prompt to copy and paste the file location, but yours opens up the workspace and you can select the file.  I'm still pretty new to iLogic and the API  so thank you for showing me that, ill be experimenting with that now for other applications!
