Is there a tool to draw 3D sketch with coordinates from a txt or excel file?
bwang-tecoustics
bwang-tecoustics
CCarreiras
Hi!
Yes... open a new  3D Sketch and insert excel info.
CCarreiras
bwang-tecoustics
But that only give me the points, I need to do the scketch again from these points? It's hard to do it if you have 100 points.
CCarreiras
Hi!
Yes... only the points...
How you expect inventor know how you want to join the points??!! lines? splines? and which order?
That you have to do mannually... 😞
CCarreiras
bwang-tecoustics
The order to join the points should be as the coordinates sequence from the excel file. and then give it an option if to connect the last point to the first point. This is what I expect that Inventor should have. Anyway, thanks for your reply.
CCarreiras
OK... you're right... so, put your idea in "ideas Station" and maybe this feature will appear in next version... i will vote!!!
CCarreiras
bwang-tecoustics
Thanks for your suggestion. I have added it in the idea station.
