Is that a way to make Browsernote = emtry in an custom library in contents center so it show Partnumber ?
Darkforce_the_ilogic_guy
Advisor Advisor
I am trying to make a custom library in content center that work with Bolted connect . And want browser note to be emtry  , so it automatict show the partnumber . is that possibly?
if it not possible how do I control that it show , so I have show the same as the partnumber
A.Acheson
I assume your talking about manually changing the display name in content center family table ? It is just a matter of mapping the display name to partnumber column. Typically it is mapped to the filename.
Regards
Alan
maybe How do i map it ?..it seens to lock .. it does change but not by me
A.Acheson
It looks like there is default internal mapping for families using family name and designation column etc. It seems to use a combination of family name and designation columns. You can map the display name by the following method in the image. Refresh  CC in the assembly then this info updates.
Regards
Alan
