I created this proof of concept script. It worked but I found it not very useful.
# https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/importing-an-assembly-document-into-python/m-p/11348656#M141139
# https://stackoverflow.com/questions/47443621/extracting-parameters-from-autodesk-inventor-with-python
import win32com.client
from win32com.client import gencache, Dispatch, constants, DispatchEx
ThisApplication = win32com.client.Dispatch('Inventor.Application')
ThisApplication.Visible = True
CastTo = gencache.EnsureModule('{D98A091D-3A0F-4C3E-B36E-61F62068D488}', 0, 1, 0)
ThisApplication = CastTo.Application(ThisApplication)
# oApp.SilentOperation = True
oDoc = ThisApplication.ActiveDocument
oDoc = CastTo.PartDocument(oDoc)
#in case of an assembly use the following line instead
#oDoc = mod.AssemblyDocument(oDoc)
prop = ThisApplication.ActiveDocument.PropertySets.Item("Design Tracking Properties")
# getting description and designer from iproperties
Descrip = prop('Description').Value
Designer = prop('Designer').Value
print("Description: ",Descrip)
print("Designer: ",Designer)
# getting mass and area
MassProps = oDoc.ComponentDefinition.MassProperties
#area of part
dArea = MassProps.Area
print("area: ",dArea)
#mass
mass = MassProps.Mass
print("mass: ",mass)
#getting parameters
oParams = oDoc.ComponentDefinition.Parameters
lNum = oParams.Count
print("number of Parameters: ",lNum)
# make sure the parameter names exist in the Inventor model
param_d0 = oParams.Item("d0").Value
print("Parameter d0: ",param_d0)
param_d1 = oParams.Item("d1").Value
print("Parameter d1: ",param_d1)
param_d2 = oParams.Item("d2").Value
print("Parameter d2: ",param_d2)
param_d0_exp = oParams.Item("d0").Expression
print("Parameter d0_exp: ",param_d0_exp)
param_d1_exp = oParams.Item("d1").Expression
print("Parameter d1_exp: ",param_d1_exp)
param_d2_exp = oParams.Item("d2").Expression
print("Parameter d2_exp: ",param_d2_exp)
Jelte de Jong
Blog: hjalte.nl - github.com
