Is it possible to run VBA code when i switch the active document?
torben_schroederXDK86
Hey.
I have created a userform which helps with saving and exporting the currently active document as needed.
Right now in the userform_initialize sub i have it fill all the textboxes, lables and so on accordingly to the filename and iproperties etc.
I have made it so i can interact with inventor while having the userform open. I can switch the document while its open.
Now i want to know if its possible to re-run the userform_initialize sub when i switch the active document. If so, how? Or are there any other ways around?
(yes i am lazy, thats why i dont want to reopen the userform everytime i want to export/save a new file)
Michael.Navara
In general it is possible, but I recommend you to use VB.NET add-in instead of VBA. There are much more possibilities to handle required events like ApplicationEvents.OnActivateDocumentApplicationEvents.OnNewEditObject, etc.
Also DockableWindow can be useful object.
Frederick_Law
Can't be too lazy.
Add a button in the from to "reload".
I used a form to launch macros, 20 years ago:
Now most of them are addin with icon in Ribbon.
Also using iLogic:
