is it possible to make your our hole feature `?
Darkforce_the_ilogic_guy
Advisor Advisor
we need to find a easy way to make this hole
the Problem is that this is an combi of counterbore and Countersink.. this is easy to make in real lift ..but Hol feature does not seems to support this ..
Is it possible to create this kind of hole feature for my self ? or is there a way I can allready do this easy(PS: I do not want to do this i 2 feature
dutt.thakar
@Darkforce_the_ilogic_guy
Try using iFeautre, this will not be incorporated in the hole command, but you can create your unique feature and save it as a standard feature and use it any time you want. see below links for more help.
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Inve...
https://www.youtube.com/watch?v=c8p-cgWiEes
https://www.youtube.com/watch?v=2sko25ysSKY
Also, I would recommend doing an extensive google search on this and you will find a lot more resources.
Hope this will be helpful.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
WCrihfield
It could be done as single RevolveFeature (instead of a HoleFeature combined with some other type of feature).  Just make sure its 'PartFeatureOperationEnum' value is set to 'kCutOperation'.  It might be a bit trickier to set-up than a HoleFeature, but sounds possible.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
What I want is make the hole like the one on the left , insted of the one on the right.
it very easy to do this in the workshop. I  need to Spotface because the guide rail because  of wear and tear over time  and the Countersink  so it autocenter for extra precision.  in the workshop you can do this in one go .. but inventor it is a lot of extra work in both 2d and 3d to make it happen. and a lot you can forget to do
matt_jlt
There are a few different solutions provided above on how to achieve the same end result but i believe the answer to your question is no. It is not possible to add a hole type to the user interface. I have this same problem and i make it from two separate hole features.
You can add a feature request / submit this as an idea if if hasn't already been done.
I have allready done this 😁
https://forums.autodesk.com/t5/inventor-ideas/combi-holefeature/idi-p/10107254
fell free  to like it
