Is it possible to get the user's name and surname (profile), and maybe other details, from Account details, VBA/iLogic code?
engilic
engilic
Just to have personalized messages, (would be nice).
I attached a screenshot with my details to specify what I want.
Thank you
JhoelForshav
Hi @engilic
Seems like you want to get the info from a360. There's a lot of information you can get using the entitlement API.
See this iLogic example for first and last name 🙂
AddReference "AddinNETFramework.AdWebServicesWrapper.dll"
Imports Autodesk.WebServices
Sub Main
	Dim firstName As String = ""
	Dim lastName As String = ""
	If GetUserName(firstName, lastName) Then
		MessageBox.Show("Hello, " & firstName & " " & lastName, _
		"Personal message")
	Else
		MessageBox.Show("Failed to get user info.", "Fail")
End Sub
Public Function GetUserName(ByRef firstName As String, ByRef lastName As String) As Boolean
	Try
		Dim webServiceMgr As New CWebServicesManager()
		If webServiceMgr.Initialize() Then
			webServiceMgr.GetUserFirstName(firstName)
			webServiceMgr.GetUserLastName(lastName)
			If firstName = "" Or lastName = "" Then
				firstName = ""
				lastName = ""
				Return False
			Else
				Return True
		Else
			firstName = ""
			lastName = ""
			Return False
		Return True
	Catch ex As Exception
		firstName = ""
		lastName = ""
		Return False
	End Try
End Function
JhoelForshav
I tried this in Inventor 2021 now and there it failed. So I added the line:
ThisApplication.Login()
before
and then it worked. So the complete code should look like this 🙂
Sub Main
		"Personal message")
	Else
End Sub
	Try
				firstName = ""
				lastName = ""
				Return False
			Else
				Return True
		Else
			firstName = ""
			lastName = ""
			Return False
		Return True
		firstName = ""
		lastName = ""
		Return False
	End Try
End Function
engilic
Thank you very much @JhoelForshav ,
This is great, works like a charm.
Is it difficult to transfer it to VBA or not?
Just not sure about the first two lines, AddReference, and Imports.
Also webServiceMgr function.
Thank you
engilic
Can anyone make this code work in VBA?
Thx
engilic
Please @JhoelForshav ,
Is it possible to get VBA code for macro, I cannot do it.
Thank you.
jake_egley
In VBA it's much easier:
Dim UserName As String
UserName = Environ("USERNAME")
MsgBox (UserName)
Jake Egley
Inventor 2022
