Is it possible to export specified sheets to DWF?
Hello Everyone,
I am working with Inventor 2020 and we're trying to get a multi-sheet drawing to DWF only a specific amount of sheets. So say the drawing is 10 sheets but we only want pages named "Client" or sheets 8-10. Is there a way to do this?
Thanks!
JamieVJohnson2
Should be so, in the dwf translator add-in's options you can specify pages to be translated.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Here is sample VBA code to publish 1st and 3rd sheet inot DWF.
Public Sub PublishDWF()
    ' Get the DWF translator Add-In.
    Dim DWFAddIn As TranslatorAddIn
    Set DWFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD95-2F4D-42CE-8BE0-8AEA580399E4}")
    'Set a reference to the active document (the document to be published).
    Dim oDocument As Document
    Set oDocument = ThisApplication.ActiveDocument
    Dim oContext As TranslationContext
    Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = kFileBrowseIOMechanism
    ' Create a NameValueMap object
    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    ' Create a DataMedium object
    Dim oDataMedium As DataMedium
    Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
    ' Check whether the translator has 'SaveCopyAs' options
    If DWFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        oOptions.Value("Launch_Viewer") = 1
        ' Other options...
        'oOptions.Value("Publish_All_Component_Props") = 1
        'oOptions.Value("Publish_All_Physical_Props") = 1
        'oOptions.Value("Password") = 0
        If Typeof oDocument Is DrawingDocument Then
            ' Drawing options
            oOptions.Value("Publish_Mode") = kCustomDWFPublish
            oOptions.Value("Publish_All_Sheets") = 0
            ' The specified sheets will be ignored if
            ' the option "Publish_All_Sheets" is True (1)
            Dim oSheets As NameValueMap
            Set oSheets = ThisApplication.TransientObjects.CreateNameValueMap
            ' Publish the first sheet AND its 3D model
            Dim oSheet1Options As NameValueMap
            Set oSheet1Options = ThisApplication.TransientObjects.CreateNameValueMap
            oSheet1Options.Add "Name", "Sheet:1"
            oSheet1Options.Add "3DModel", True
            oSheets.Value("Sheet1") = oSheet1Options
            ' Publish the third sheet but NOT its 3D model
            Dim oSheet3Options As NameValueMap
            Set oSheet3Options = ThisApplication.TransientObjects.CreateNameValueMap
            oSheet3Options.Add "Name", "Sheet:3"
            oSheet3Options.Add "3DModel", False
            oSheets.Value("Sheet2") = oSheet3Options
            'Set the sheet options object in the oOptions NameValueMap
            oOptions.Value("Sheets") = oSheets
    'Set the destination file name
    oDataMedium.FileName = "c:\temptest.dwf"
    'Publish document.
    Call DWFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
