Is it possible to disable the sketch update?
stefanome
stefanome
I have a function that adds many entities and constraints to a sketch, and it's very slow because it updates the sketch after each constraint is created.
Is it possible to turn off the automatic update, add all the entities and constraints, then turn on the update?
Stefano
Use Sketch.DeferUpdates property
See also the sample "DeferSketchUpdate" in the Inventor API Help
stefanome
That's what I was looking for.
Unfortunately reduces the time from 2.9 to 2.3 seconds only, I was hoping on a bigger difference.
You may also try user interaction disabling
oApp.UserInterfaceManager.UserInteractionDisabled = True
... Place your code here ...
oApp.UserInterfaceManager.UserInteractionDisabled = False
This usually works in the out-of-process applications.
Be careful with possible errors because end user can do nothing in Inventor when this interaction is disabled
