Is it possible to customize the basic operations of inventor?
Miguel.CarvajalS34Q6
hello,
It is to generate a code that differentiates me from the basic operations of Invetor, for example: extrusions, rounding, holes, chamfer, etc.
and give the operation a color, to identify the different operations that each model has.
thanks.
Frederick_Law
It will be a very long code.
An addin that watch every command IV use and change color for each command.
You'll need to find name for each command and decide which color for each command.
And it could slow down IV because something need to be done for each command.
This will list all commands:
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-902D34CA-4543-436C-AFF3-83F3386A2FD1
There are over 3000 commands.
Every time a command start, the code will check command name and see if it need to change color.
The event is: UserInputEvents.OnActivateCommand
Michael.Navara
If you want just analyze existing model, you can use this simple code to change color.
This code expects the appropriate color assets exists in part document
Sub Main()
    Dim part As PartDocument = ThisDoc.Document
    Dim partDef As PartComponentDefinition = part.ComponentDefinition
    For Each surfaceBody As SurfaceBody In partDef.SurfaceBodies
        For Each face As Face In surfaceBody.Faces
            Dim color As Asset
            Select Case face.CreatedByFeature.Type
                Case ObjectTypeEnum.kExtrudeFeatureObject
                    color = part.AppearanceAssets("Extrude")
                Case ObjectTypeEnum.kRevolveFeatureObject
                    color = part.AppearanceAssets("Revolve")
                Case ObjectTypeEnum.kHoleFeatureObject
                    color = part.AppearanceAssets("Hole")
                Case ObjectTypeEnum.kFilletFeatureObject
                    color = part.AppearanceAssets("Fillet")
                Case ObjectTypeEnum.kChamferFeatureObject
                    color = part.AppearanceAssets("Chamfer")
                    'Etc.
                Case Else
                    Continue For
            End Select
            face.Appearance = color
        Next
    Next
End Sub
Michael.Navara
Another approach is to use HighlightSets. This solution only temporarily change color in active view and doesn't modify part document
Sub main
	HighlightFaceByFeature()
End Sub
Private Sub HighlightFaceByFeature()
	Dim extrudeFaces As HighlightSet = part.CreateHighlightSet()
	Dim revolveFaces As HighlightSet = part.CreateHighlightSet()
	Dim holeFaces As HighlightSet = part.CreateHighlightSet()
	Dim filletFaces As HighlightSet = part.CreateHighlightSet()
	Dim chamferFaces As HighlightSet = part.CreateHighlightSet()
	extrudeFaces.Color = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
	revolveFaces.Color = ThisApplication.TransientObjects.CreateColor(0, 255, 0)
	holeFaces.Color = ThisApplication.TransientObjects.CreateColor(0, 0, 255)
	filletFaces.Color = ThisApplication.TransientObjects.CreateColor(255, 255, 0)
	chamferFaces.Color = ThisApplication.TransientObjects.CreateColor(0, 255, 255)
	For Each SurfaceBody As SurfaceBody In partDef.SurfaceBodies
		For Each Face As Face In SurfaceBody.Faces
			Select Case Face.CreatedByFeature.Type
					extrudeFaces.AddItem(Face)
					revolveFaces.AddItem(Face)
					holeFaces.AddItem(Face)
					filletFaces.AddItem(Face)
					chamferFaces.AddItem(Face)
					'Etc.
				Case Else
					Continue For
			End Select
		Next
	Next
End Sub
To clear preview you can use this code
For Each hs As HighlightSet In part.Highlightsets
	hs.Delete()
Next
part.Update
