Is it possible to convert a variable from an ipart table to a drawing variable?
Miguel.CarvajalS34Q6
I have values or a description in the member section for each configuration in ipart; and I want it to be reflected in the drawing when I insert the part
A.Acheson
If the iproperty are added to the factory table then that iproperty is retrievable for each member either in the model or drawing. Are you looking to retrieve the iproperty by code or manually? Where is the iproperty being displayed , the title block or custom table?
Regards
Alan
I would like to retrieve the property by code, so that the format is automatically filled
