is active = true/false
salih_kapucu
salih_kapucu
I made a cutting process that can be opened and closed independently of each other on the right and left of the product in the video.
the right side is traded independently, but when I trade on the left side, the right side is affected.
I did not write such code. the system is not working properly.
Can you help me solve this?
A.Acheson
Can you attach the part (.ipt).  Check also that each parameter is corectly link in model and user parameter. Work with left only extrusion first to ensure it functions before moving to the right.
Regards
Alan
salih_kapucu
Hi Acheson,
The relevant file is attached.
tyler.warner
@salih_kapucu could you post the code that is in your rule to turn on/off the cuts?
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
