Is a weldbead a virtual component?
SharkDesign
Mentor Mentor
SharkDesign
Is a weldbead a virtual component and what is the best way to ignore them in an occurrence loop?
They keep messing up my code.
  Inventor Certified Professional
Sergio.D.Suárez
Hi, it is known that the Try -Catch - End try instructions cannot coexist with on error resume next on the same line, however if you separate the code in subroutines you can implement them together and avoid errors in a loop.
Can you share an example of error to analyze it?
Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
SharkDesign
Well you can't do anything with a weldbead, so if you're trying to match iproperties for instance it'll crash.
I even have weldments with no welds in at all and it still gives an error on weldbead occurances.
Sergio.D.Suárez
Here I show you a third method without functions that work with the error.
This rule works in a Weldment assembly.
Here I avoid the occurrences and those that have the same fullfilename as the assembly, and only take the remaining ones.
Then I execute an action on the remaining occurrences.
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oCD As WeldmentComponentDefinition = oDoc.ComponentDefinition
Dim doc As Document
Dim oFullName As String
For Each oCc As ComponentOccurrence In oCD.Occurrences
	doc = oCc.Definition.Document
	oFullName = doc.FullFileName
	If oFullName <> oDoc.FullFileName Then
		oPartNum = doc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
		MessageBox.Show(oPartNum)
Next
 I hope it works for your particular case, if not, see if you can share a basic example that throws an error.
Regards
Mechanical Designer
Curtis_Waguespack
Hi @SharkDesign
Here are some ilogic examples that might help.
I hope this helps.
Curtis
Does report weld beads
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim oOcc As ComponentOccurrence
For Each oOcc In oAsmCompDef.Occurrences.AllLeafOccurrences
	MessageBox.Show(oOcc.Name, "iLogic")
Next
Does NOT report weld beads
	If oOcc.Name.Contains("_Weldbead") = False Then
Next
Next
Next
For Each oOcc In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
Next
