Is a fillet external
I'm iterating through all fillets on a sheet metal component, but need to identify ONLY the external fillets, ignoring the internal ones.
How best to do this??
If oFilletEdgeSet.AllRounds = True Then
The above would seem to be the solution in identifying if the fillet is internal or external so
Dim oFilletEdgeSet As FilletConstantRadiusEdgeSet  I would need this but,
Set oFilletEdgeSet = ?????  this is where I get stumped  😞
As always help and guidance would be greatly appreciated as I'm not an instinctive programmer.
YuhanZhang
Suppose that you have a fillet feature oFilletFeature, and then you can get the FilletEdgeSet as below:
Set oFilletEdgeSet = oFilletFeature.FilletDefinition.EdgeSetItem(1)
Debug.print oFilletEdgeSet.AllRounds
if you have multiple edge sets in that fillet feature, you can transverse over the edge sets. Hope this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Thank you.
It was the EdgeSetItem(1) where I got confused.  I should have realised there could be more than 1 item in the set and that this was indicated on the API Object Model drawing by the (x) !!
