iProperty concatenation with iLogic
karthur1
Mentor Mentor
karthur1
I would like to be able to concatenate the title of my part using iLogic.  I would like it to read this:
"TEXT 12.5in TEXT (1 1/2 x12.5 x 20)"
The "12.5in", "12.5" and the "20" are all variables that I am setting with ilogic.  As the part changes so do these variables.  Its probably something very simple, but I cant get it to do it.
I have tried this, but it gives me an error.
iProperties.Value("Summary", "Title")="TEXT"Cutlength"TEXT"Width "x" total"
PaulMunford
Check this out:
http://msdn.microsoft.com/en-us/library/wfx50zyk.aspx
Customer Adoption Specialist: Autodesk Informed Design
Help | Learn | Forum | Blog | Ideas | Sample content | Linkedin
Curtis_Waguespack
Hi karthur1,
In addtion to Paul's answer, this link from the Inventor Customization forum provides an example as well:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Part-Number-driven-by-parameters/m-p/3...
I hope this helps.
Curtis
karthur1
I was way over-thinking this.  I could actually do what I needed this time using formulas in my iproperties.  I can see this being useful later though.
Thanks.
karthur1
There are times when I need to populate the iproperty fields with iLogic rather than with a formula in iproperty.
When that is the case, here is how it can be populated.
If you need to format the expression as fractional, here is a way to do that also.  Use the RoundToFraction function.
