iProperties.Value in IDW
I try to change the iProperties value PROJECT automatically in an IDW - file. I use this script, but somehow it doesn't work.
I think i don't use the right  iProperties.Value("Project", "Project")
Who can help me.
In the IPT-file this script works fine.
A=ThisDoc.Path
A=Right(A,6)
iProperties.Value("Project", "Project")=A
This how you Iproperties are accessed in drawing document and it can be changed.
This may provide you a overview on iproperties.
Sub test()
' Get the active Drawing document
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
' Get the PropertySets collection from the drawing
Dim oPropSets As PropertySets
Set oPropSets = oDoc.PropertySets
' Get the user Defined property set
Dim oPropSet As PropertySet
Set oPropSet = oPropSets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
Debug.Print oPropSet.DisplayName
' List all the properties in this set, and change the value to "Changed"
Dim oProp As Property
For Each oProp In oPropSet
Debug.Print oProp.Name, oProp.Value
oProp.Value = "Changed"
Next
End Sub
-Varadan
