iProperties Not Visible
When I click the iProperties button on the Edit Property Fields the iproperties don't pop up however it acts like the iProperties are open. When I click anywhere in AutoCAD it makes the ding that windows does when you have a risen window that's in control and the only way for me to get out of that stasis is to Alt-F4 for the iProperties window that acts as if it's present and then I am sent back into the Edit Property Fields (naturally). I tried tiling all windows on my system and it's still not there.
I don't know what causes this issue because it's not constant. The only correlation I can see is that it occurs when the part is saved in certain folders. I made a folder and had the problem and I was able to use someone elses computer to edit the iProperties and it still wouldn't load on mine. It didn't bother me as much until it occured on more folders. So the problem is with my program or computer.
If anyone can help that'd be great!
