iProp to browser tree
GosponZ
Message 1 of 8
GosponZ
I'm using this rule for long time, and now need to add custom property to this rule. Could you guys help me?
'This rule will make in browser part number, description,
oDoc = ThisDoc.Document
oSheets = oDoc.Sheets
    For Each oSheet In oSheets
        oSheet.activate
        oView = oSheet.DrawingViews.Item(1)
        modelName = oView.ReferencedDocumentDescriptor.ReferencedDocument
        oProp = modelName.PropertySets.Item("Design Tracking Properties")
        ActiveSheet.Sheet.Name = oProp.Item("Part Number").Value & " " & oProp.Item("Description").Value& " " & oProp.Item("Authority").Value
    Next
oSheets(1).activate
iLogicVb.UpdateWhenDone = True
Accepted solutions (4)
Replies (7)
Message 2 of 8
JhoelForshav
@GosponZ
Are you looking for something like this?
        oSheet.activate
		ocProp = modelName.PropertySets.Item("Inventor User Defined Properties") 'Custom property set
        ActiveSheet.Sheet.Name = oProp.Item("Part Number").Value & " " & oProp.Item("Description").Value & " " & oProp.Item("Authority").Value _
		& " " & ocProp.Item("NAME GOES HERE").Value
    Next
oSheets(1).activate
Message 3 of 8
Martin-Winkler-Consulting
There are 4 Property Sets in Inventor.
Inventor Summary Information/{F29F85E0-4FF9-1068-AB91-08002B27B3D9}
Design Tracking Properties/{32853F0F-3444-11D1-9E93-0060B03C1CA6}
Inventor User Defined Properties/{D5CDD505-2E9C-101B-9397-08002B2CF9AE}
Inventor Document Summary Information/{D5CDD502-2E9C-101B-9397-08002B2CF9AE}
You can call the Property Sets with Name or the Guid for example the User Defined Properties:
or
.PropertySets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
If you need more information have a look to this blog post:
https://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
Message 4 of 8
GosponZ
Thank you it is working
Message 5 of 8
GosponZ
Thank you
Message 6 of 8
GosponZ
As i said it is working no problem at all. When i place assembly on sheet code doesn't work.
Is it there way to skip assembly. Problem is they want save dxf file as material, part description, and total qty from assembly for that part. With only parts no problem. Would  you guys try to help.
Message 7 of 8
JhoelForshav
Hi @GosponZ
Try this to skip the property based naming if the view's referenced document is not a part document 🙂
	oSheet.activate
	If modelName.DocumentType = DocumentTypeEnum.kPartDocumentObject 'Only set property based name for part views.
Next
oSheets(1).activate
Message 8 of 8
GosponZ
Thank you works good
