iPart and iLogic Error
chayman
chayman
Hey guys,
I am creating a axial fan assembly with a casing and 2 flanges on both sides. However, the casing and flange (diameter & length) will change depending what model I selected. Our company has over 50+ models so I thought using iParts was the best route to go. Here is what I have done so far:
1. I created an iPart for the fan casing (12 in) with the following members; 126, 124, 124V, 122 and 122V
           * they vary in Diameter and length*
2. Created an Assembly and dropped the 1 X Casing iPart and 2 X Flange
3. Created a user parameter in the assembly called "Model". This would allow me to select one of my fan models.
4. Created an iLogic ruled named "Fan Size". What I want this to do is find the model I select in the iPart Table (for example 126) and grab the dimensions for it's given Diameter and Length.
I keep getting this error message:
Error in rule: Fan Size, in document: Master_Axial Fan_Template.iam
iPart.CurrentRowValue("Length"): This function was called without a previous call to iPart.ChangeRow or iPart.FindRow.
Is there a reason why my code isn't working?
SyntaxEditor Code Snippet
iPart.ChangeRow("Master_Axial Fan_Casing:1", Model)
Length = iPart.CurrentRowValue("Length")
Diameter = iPart.CurrentRowValue("Diameter")
iLogicVb.UpdateWhenDone = True
 Please see attached models for your reference.
NSBowser
Chayman,
ChangeRow requires the Row Member by name to select the row and errors at subsequent lookups if it couldn't change the row successfully. I might suggest using FindRow and find the column which matches the value of 'Model'. It will return an 'i' value which will = -1 if it fails to find one, you can check if i = -1 then return a message the row wasn't found. Otherwise it will find AND change the row for you to then follow with subsequent Lookups.
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
