Inward rounding of secondary unit tolerance extents
sbalasubramanianJJDFU
Hello experts,
Im trying to set Inward rounding of secondary unit tolerance extents.
In solidworks , For the secondary units of dual dimensions, you can set the limits of the secondary unit’s tolerance range to fit within the tolerance range of the primary unit by using inward rounding so that the dual dimension does not conflict with the primary dimension.
https://help.solidworks.com/2015/english/whatsnew/c_decimal_rounding.htm
Is there a similar feature in Inventor so that the dual dimensions alternate unit precision level is always set based on the primary unit's value. Appreciate your reply. thanks!
daltonNYAW9
This sounds like it would be stored in the "Design data" if this were an option. However I couldn't find anything in the styles editor ui.
Something I did find that you might want to look into....
If you go to your design data folder and under "dimensions.xml". Each dimension type is set to: RoundOption="0"
Didn't test this but it looks promising.
