Inventor wihtout VBA , what are replacing it ?
Darkforce_the_ilogic_guy
Advisor Advisor
i know inventor 2021  does not have VBA install as standard.  are Autodesk add something to replace it ? I have a lot of Marco that use the VBA most of them simple run an Ilogic code.. but also have a few  that do other stuff .   I do not know want we are updating next time ... but what come to replace it ? I want to plan ahead
The VBA modules have not been part of the standard install for Inventor & AutoCAD for a few releases now, you can download the Inventor VBA module here
I believe that this was done for security reasons, as it is quite easy to create a VBA exploit.
If you are writing anything that is not suitable for iLogic you should consider writing an add-in, or add-ins.
As far as I now it was a part of our release in inventor 2020.
Most of my VBA is simple run this this illogic code.. I am not just if I can make the VBA other VBA to illogic . But I mostly use to make bottom with Icon on It to our User command toolsbar .
I do not have the Skill or the Program I believe to be needed at this point to make Add-in/Add-ins
