Inventor Viewer API
Inventor Viewer API
Message 1 of 10
Inventor Viewer API
Does the Inventor Viewer have a API that I can use? I am interested in opening a drawing with an Inventor Viewer and after that send the document automatically to printer. Can this be done automatically?
Replies (9)
Message 2 of 10
you don't really need the viewer! Have a look at the SDK sample "Standalone Applications\ApprenticeServer\FileDisplay"
Bernhard
Message 3 of 10
yes, you may be right. But do you know if the apprentice supports printing or exporting to pdf?
Message 4 of 10
Hi
yes apprentice supports printing but as I know not tools which need translator add ins like
PDF STEP SAT  ...
The only way is to use free PDF Printers! Before IV has supported PDFs I have used a standard PostScrip Printer and converted it with GhostScrip to PDF. Then you can use apprentice!
Bernhard
Message 5 of 10
Which is the print method? I want to use a printer that in facts prints to pdf.
Message 6 of 10
It's the same as the standard one, but you have to use ApprenticeServer and ApprenticePrintManager!
Bernhard
Message 7 of 10
yes ... found it. I tried using the PrintToFile method hoping to get easy with it. But when I try to open the pdf file it gives me an error. Any ideea why?
Message 8 of 10
Yes you need a printer with API! Thats the reason for my workaround with PostScript and GhostScript!!
Bernhard
Message 9 of 10
Yes you are very right. I am sorry for being so impacient, but I was doing some tests while searching answers on forum. Looking through Autodesk forum I found out that in fact PrintToFile creates a PostScript file, not a pdf file. I transformed it into a PDF using PDFCreator. Now I have a nice good looking PDF.
Thaks a loot for all the help.
Message 10 of 10
No problem 🙂
Bernhard
