Inventor View Control .ocx add in VS2012 on Windows 7 64 bit computer
Hello All,
I am really having trouble getting the InventorViewCtrl.ocx to be recognized by VS2012.
I did register the bin32\InventorViewCtrl.ocx with C:\sysWow64 but no go.
Any help would be greatly appreciated.
Bob
adam.nagy
Autodesk Support
Autodesk Support
Hi Bob,
That ActiveX control is 64 bit on a 64 bit OS, so VS will not see it and you would need to add it dynamically like other 64 bit controls:
http://adndevblog.typepad.com/autocad/2012/07/use-64-bit-activex-component-from-a-net-assembly.html
I hope this helps.
Cheers,
Adam Nagy
Autodesk Platform Services
