inventor vba user parameter
Message 1 of 8
Hello everyone,
I was trying to put together a vba for inventor that would let user browse for excel file with three columns; column A for name of parameter, B will be value and C units. Then vba will loop through the excel get the parameter name and see if it exist in the inventor file, if so it will just get the value and unit ,if not it will create the user parameter. So far I got the vba to browse for the file and open and after that I couldn’t figure out how to do the loop. when i run the vba it let me pick the excel file then it will freeze. With the help of this forum I have an ilogic rule that does it but I am trying to have the vba version of it. i have attached the vba i have as  a text. sample vba or guidance will be appreciated. Thank you very much.
Replies (7)
Message 2 of 8
NachoShaw
Hi
You could do the following (no coding supplied)
Open excel
County how many rows have data
Get the row count and do a loop
For I =0 to RowCount
Get each value and check with Inventor
Next I
I've never been a fan of Do While
FYI
Your inventor code opens a connection each loop. That could be a lot of memory. You would be better with a routine that
Makes a single connection to the doc and keep it
Store the connection as a variable
Move the code for inventor to a function
Call the function passing the active doc
Do your looping
Close the connection.
An example:
Sub GetParams ()
'Make your excel connection here
'Loop your parameters here
'Row Count = amount of rows with data
Dim oDoc As Document
Set oDoc As ThisApplication.ActiveDocument
For i = 0 to RowCount
ParamName = Row.Value
Call CheckParams (ParamName, oDoc)
oDoc.Close
oDoc = Nothing
End Sub
Function CheckParams (ParamName As String, doc As Inventor.Document)
'Do your inventor work here using ParamName & Doc
End Function
This is one connection to excel, one connection to the Inventor Document.
If you struggle, give me a shout and i'll rustle something up
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Message 3 of 8
Nacho,
Thank you for taking the time to help me out. Sorry I forgot to mention it but I am completely new to vba and so far my experience have been to get codes from forums/help file then modify them to fit my need. I did try to build upon the example you provided me but I couldn’t get anywhere after researching for a while. Attached is what I did based on your suggestion not sure if I even did that right, could you build upon it when you get the chance.
Sincerely,
Adam t.
Message 4 of 8
NachoShaw
no probs mate,
i'll take a look tomorrow (Friday)
cheers
Nacho
Nacho
Message 5 of 8
NachoShaw
Hey man
Sorry I got occupied elsewhere. If you want to send me your project / file / workbook, I'll sort it out tomorrow
Cheers
Nacho
Nacho
Message 6 of 8
NachoShaw
Email nmjshaw at Outlook dot com
Nacho
Message 7 of 8
Just sent you an email. Thanks.
Message 8 of 8
NachoShaw
got it mate, will look at it later
cheers
Nacho
