Inventor VBA system error &H8007003B
r.paauwT7BR9
r.paauwT7BR9
In Inventor I have a macro that uses a UserForm. The userform has buttons to select the option to perform stepfile export on a single or on multiple open .ipt or .iam. Most of the times the macro runs without problems. But sometimes it has a Run-time error "7": could not find specified object. When pressing debug, the code
Set oUserform = New oUserform is marked.
Code sample:
dim oUserform as oUserform
set oUserform = New oUserform
When trying to open oUserform the System Error &H8007003B (-2147024837) appears.
Can someone help me understand this problem?
yan.gauthier
Simply call your form using the method myform.show
If your form name is StepExportForm, then in your code, you would call StepExportForm.show
r.paauwT7BR9
Sorry for the late reply.
Your solution means I do not have to declare the form first?
yan.gauthier
You should have created your form in the VBA editor. You don't need to declare it. simple call the show method
