Inventor VBA - Split Feature with Selected Face and Visible Workplane
08:46 AM
Hey all, I'd appreciate any help provided.
My code prompts the user to select one face that's part of a surface body (the surface body has multiple faces that I developed from manually using the splits feature) and uses a visible workplane to perform a split all the way through.
The split on the face wont work at all. When I add the oFace.Surfacebody portion to my code, it performs the split but on the entire surface body parent.
I've tried the Faceproxy, Facecollection methods too and can't seem to find something that disnguishes just that one face I selected to be sliced
Again, I appreciate the help guys and gals
Here's my code:
Public Sub SplitAllSurfacesOfSelectedSingleSurfaceBodyFace() 'Define Partdocument and Split Feature to use Dim oPartDoc As PartDocument Dim oCompDef As PartComponentDefinition Dim oSplit As SplitFeature Set oPartDoc = ThisApplication.ActiveDocument Set oCompDef = oPartDoc.ComponentDefinition 'Define workplane object Dim oWorkplane As WorkPlane 'Planes of Interest to Skip Dim YZ As String Dim XZ As String Dim XY As String 'Workplanes names to Skip YZ = "YZ Plane" XZ = "XZ Plane" XY = "XY Plane"
'Prompt user to select face Dim oFace As Face Set oFace = ThisApplication.CommandManager.Pick(kPartFaceFilter, "Pick Face") 'Create splits using visible workplane and selected surfacebody-face For Each oWorkplane In oCompDef.WorkPlanes 'Only utilize the current visible workplane If oWorkplane.Visible = True Then If oWorkplane.Name() <> YZ Then If oWorkplane.Name() <> XZ Then If oWorkplane.Name() <> XY Then On Error Resume Next 'place this in there for the instances where the plane object doesn't posses the Driveby.Name property
'Take the remaining workplanes and slice and dice Set oSplit = oCompDef.Features.SplitFeatures.SplitFaces(oWorkplane, _ True, oFace.SurfaceBody) 'Slices the surface body parent object, but not what I want ' True, oFace) 'does nothing with the face
End If End If End If End If Next oWorkplane MsgBox "The splits are now complete."
